Code FE means its doing noise but dont wash at all
I get an FE code on my samsung WD0704RQQ short time after setting the machine on dryer mode. Please help as my manual doesnt have the code and its meaning.
http://appliancejunk.com/forums/index.php?topic=17042.0
I SUGGST REMOVING POPWER, SHUT OFF BREAKER, THEN RESET, IF IT DOESNT HELP IT WOULD NEED SERVICE
Apr 14, 2016 | Samsung Washing Machines
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Mar 01, 2014 | LG WM-2077C Front Load Washer
Fe warning light
Fe error code means "Water Overflow Error". Check the upper level sensor of the machine.
Dec 22, 2013 | LG Washing Machines
FE code
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Oct 13, 2012 | LG Washing Machines
What does FE code mean?
KENMORE TOP LOAD WASHER WITH FE CODE WHAT DOES THAT MEAN?
Sep 17, 2012 | Kenmore Elite 45986 Front Load Washer
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
What does a flashing code of "FE" mean? I cannot get the machine to stop beeping nor can i unlock the door?
Hi
Thanks for using FixYa. FE is Overflow error which means that the water is overflowing and the water level frequency is over 213. When FE error is displayed the drain pump operates to drain the water automatically. To resolve this issue you’ll have to check the water inlet valve and pressure sensor which can sense the water level in the tub, if any of this goes bad overflow occurs. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG Washing Machines
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
"FE" Error code on Lg Washer #2277HB
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Washing Machines Logo
Top Washing Machines Experts
