Question about HP Boating
Link and sync on 1993 Evinrude 115 hp 90 degree cross flow
  • 52 Answers
SOURCE: 1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Posted on Apr 14, 2009
  • 77 Answers
SOURCE: johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
Posted on Jun 23, 2009
  • 1865 Answers
SOURCE: oil weight to use for 1989 evinrude 2 stroke 90 hp
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
Posted on Sep 29, 2009
  • 13 Answers
SOURCE: 1970 115 evinrude wont start
remove starter and try bench testing the starter...if it works you have problems with the engine...
Posted on Oct 09, 2009
  • 49241 Answers
SOURCE: How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Posted on Apr 25, 2010
Evinrude E-tec 115 hp 2007 model No power to engine or hydraulics
Sounds like a fuse has blown, look behind your dash panel.
Mar 15, 2017 | HP Boating
How do I change the Waterway 48 frame side discharge to the opposite side?
You should be able to remove the pump housing and rotate it 90 degrees or 180 degrees. Then replace bolts and see if your good to go? Thank you Joe have a pleasant day. Leave feedback.
Jul 14, 2016 | Waterway 1.5 HP 115 Volt 2 Speed Side...
115 hp evinrude outboard motor ocean pro serial no g4045482 do you know the model number
Hi Dave I google "115 hp evinrude out board motor ocean pro serial no g4045482" and found a short Utube video so if you wanna check out the link here it is.. CHEERS-->
Mar 14, 2016 | Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Where can i download afree repair manual for 1983 evinrude 115 hp
go google and type in workshop manual for evinrude outboard motor and there are pages of manuals
a page called tradebit. com has the manuals in pdf version so look for a book that suits your requirements
Jun 24, 2015 | Boating
D link dir 615. Weak signal, router is put on main floor,but we are only getting 2 bars on the computer upstairs, and almost no signal in the basement. How can we improve the signal or do we have the wrong...
Try turning the router 90 degrees, and measure the strength.
Turn it another 90 degrees, and measure again.
Move to a house with wood cross-beams, instead of metal cross-beams inside the first-floor ceiling.
Rotate the upstairs computer 90 degrees, and measure again.
Buy a "Wireless N" router, for greater signal strength.
Oct 09, 2009 | D-Link DIR-615 Wireless Router
Boating Logo
Top HP Boating Experts
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a HP Boating Expert? Answer questions, earn points and help others
