Power button blinks and dvd vcr select buttons blink at the same time . How do I reset
premtech
  • 934 Answers
SOURCE: Power Button Blinking Red
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
If I can help any other way just let me know...
Good Luck!
Bill
Posted on Dec 01, 2007
SOURCE: playstation 2 reset button blinks.
Same here, mine just cut out when i was playing it and now the power button blinks and before there was a clicking sound. I had mine for 4 years. I guess it was do?
Posted on Aug 17, 2008
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 01, 2009
  • 8457 Answers
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Posted on Aug 20, 2009
SOURCE: power went out, now the tv just blinks at me. I
Does the blinking continue non-stop forever? If it does, it is most likely the CAPS in the DM module. If you can solder or know someone who can, this is a fairly simple repair. Some sets have 4 CAPS, yours (WS-65711) should have 7 in the DM module that will need replacment. There are many step by step sets of instructions on how to do this repair. Google mits blinking green light of death. You will find loads of information and help.
Posted on Jan 06, 2010
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
How do i program this remote to a mitsubishi tv?
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Oct 20, 2009 | Big Button TV Universal Remote
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
Oct 02, 2009 | One For All URC-3021 Remote Control
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Pioneer XV-DV99 high definition DVD/Rewriter
Try one of these codes:
221, 222, 154, 160, 174, 180
Or use the Seach feature:
Hope that fixed ya...
Geno
Mar 28, 2008 | Televison & Video
Easy one: how do you set the time on the panasonic DMR-ez47v dvd?
OPEN CENTRAL PANEL,PUSH THE 'CLOCK 'BUTTON.IT BLINKS THE PRESETED YEAR.PRESS '-/+' BUTTONS TO SET THE YEAR.THEN PUSH 'NEXT' FOR '"MONTH ,DAY,HOUR,MIN".FOR EACH TIME PRESS NEXT BUTTON & +/- KEYS.
YOUR PROBLEM MAY SOLVE.
Feb 24, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
