Question about GPS
Inesca marbella manual - GPS
I have brought a Bruin marbella cot tho it has no instructions and I can't figure out the drop side any help or instruction book greatly appreciated
16e3bc79-bc95-439c-87ed-08b37895475e.jpgI have a copy of the manual if you want it, ill copy it for you and the supplier is hunter leisure they only have the bottom guide pin available for it nothing else any more
Aug 07, 2011 | Computers & Internet
Where can i buy this stroller
for baby stroller go for lussobaby store. here you find a wide range of strollers for your baby
Oct 30, 2010 | AlloBaby Marbella 12 Jogger
Tire tube flat
have you tryed a bike shop?? or a car tyer shop??,,they may get one for you,,if that fales try that tyer fix it stops leaks in tubless tyers
Jul 05, 2010 | AlloBaby Marbella 12 Jogger
There is no evidence of any sats beig located when looking at the sat data screen. There are no errors in the error log screens. The problem was at first intermittent and then came hard on. Occurred whilst...
If the unit is fully charged and has a clearv view of the sky but fails to connect then the SIIRF chip is damaged. Expensive to repair and often not worth the trouble. This problem is not covered by warranty as it has been induced by misuse.
Plugging it to the Dc when staring the engine will do this type of damage. often not in manual to avoid this practice. only brand i have seen that warns about this is marbella altina, which is a good brand of GPS ( see marbella australia FAQ page )regarding what they say bout using GPS. Not just GPS but mobile phones can also be damaged this way.
Garmin and TOMTOM seem to be more prone tom this type of damage than the Altina. I write for many fixya type groups and rarely see any Altina problems compared to garmin and TomTom. With 1,.2 million GPS in circulation they have to be good
Jul 06, 2009 | Garmin Nuvi 660 GPS Receiver
Signal lost...system doesn't kick in for about 10 minutes
possibly a low or failing battery, You might want to also add an external antenna. Might i suggest the 50Db Skymaster from Marbella Australia, so change battery and check and invest in the antenna from marbella aust
Jun 30, 2009 | Tomtom GO 300 GPS Receiver
My tom tom signal keeps dropping out for hours
ok my aussie compatriot your problem is mainly the battery not being fully charged on the ac charger, it also needs a clear view of the sky. most tomtoms have an external antenna port mmcx but dont buy thoise cheap 28db units as they are trouble, go to Marbella Australia and get one of their 50Db external mouse antennas and that will help
tremendously. Perhaps dump your tomtom while your at it as they are nothing but trouble. just check the numer of issue son this forum.
check out the A8010 or the super A860 on the marbella site then sell off your tomtom
Jun 20, 2009 | Tomtom ONE 3rd Edition GPS
Unit indicates mapcard not inserted properly but it is
card is possibly blank send it back. buy a marbella altina Nextar are unreliable GPS If in Australia see www,nettiser.com.au/marbella/
e3ven outside australia the maps are available for all countries and the unit is reliable and easy to service, also has a mkap backup service if registered.
Jun 20, 2009 | Nextar X3-03 Car GPS Receiver
Chrysler voyager 2.5td se 97
sounds like the catalytic converter is plugged up
Aug 24, 2008 | Chrysler Voyager Cars & Trucks
Loading my Lavamat with 38° Solar heated water
can't see any reason why you can't use solar heated water as long as the pressure is sufficient for the machine. this is important
Jul 03, 2008 | AEG Lavamat 74640 Front Load Washer
GPS Logo
35 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
