Question about Viking Washing Machines
On a Viking oven there's a symbol of a padlock which when held for 3 seconds makes the display buttons not operate thus protecting young children. Any idea how to make the display operational again?
  • 1462 Answers
SOURCE: Problem with main fan oven - electric
there is an overheat stat and this is operating and cutting out the oven. the causes are several but here are the main things to look for: oven stat is faulty causing the oven to overheat. you should check over the range to see if stat is reasonably accurate. overheat stat itself is faulty. there is another stat which turns on the casing fan. (this is the fan which is out of sight - not the fan inside the oven) if this stat is faulty and not turning on the casing fan, then the overheat stat will operate. the casing fan is faulty or jammed. lack of ventilation. see if you can narrow it down a bit and get back to me if you wish
Posted on May 06, 2007
  • 1462 Answers
SOURCE: Display clock failure so no main oven
check you have power to clock and if not, check wiring back to find out why not. to get oven working, you can bypass the clock by joining the two wires to the clock relay. these clocks are remarkably expensive
Posted on May 07, 2007
  • 641 Answers
SOURCE: F1 shows on display and beeps constantly.
The F1 error code relates to a defective touch pad or clock (ERC). It seems that the reason for it in your case is some liquid entered the unit during its cleaning. Unplug the power cable and wait for few hours, In case it will not help, apart the ERC unit and and dry the touch pad and the clock. Good luck!
Posted on Sep 06, 2007
SOURCE: Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Posted on Jan 09, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WS-65909 w/a steady blinking
Only one of two reasons for your problem--either the DM is bad OR:
These sets sometimes develop a problem with the front keyboard---micro switches in back of the plastic buttons can fail (reset one is common).
Remove front speaker grill and inspection plate behind it and follow the group of wires coming down from the front keyboard to the right top edge of the opening.
About 8 inches to the right you will find two plugs that are inline--they go to the keyboard--disconnect both and turn set on with REMOTE (remote receiver is behind the screen).
If the set now functions you have a bad micro switch on the keyboard (most likely the reset) and two choices---either leave the keyboard unplugged and just use the remote or remove entire screen and get at the circuit board and locate and replace defective micro switch.
Lots of people miss this as a possible choice--easy to do to either know it is the keyboard or not.
If set does not operate this way DM is bad regardless of how caps look.
Posted on Feb 08, 2010
Testimonial: "Thanks. I had found and tried the front control panel solution prior to your response but to no avail. Thanks for the help. Take care."
When I attempt to enter anything with the keypad the display says "locked". Is there some way to unlock it.
Many microwaves have children locks. Of course they are for safety reasons. they are for tricking the little kids from playing with the big people toys.
Process A
To Turn the Control Lockout Feature On or Off:
  1. Make sure the microwave oven and timer are off.
  2. Press and hold the CANCEL keypad for 3 seconds.
  3. 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
  4. Repeat to unlock. Again, 2 tones will sound.
Process B
  2. Press and hold the START keypad for 5 seconds.
  3. 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
Hope this helps?
Jan 12, 2016 | Microwave Ovens
Oven door locked after power outage
Usually, on electronic oven controls, the user must clear the "PF" error or other such similar condition first. Next, look for a set of buttons with "lock" below them or a "key" symbol. You would then press and hold both buttons for 3-4 seconds until the lock light goes out, or a message will show "disable". I don't know what model range you have so I am giving options that I have seen in the field. On some ovens, just a single button is pressed and held--some models have a separate "cooktop lockout" and an "oven lockout". This prevents children from either activating or changing settings when un-supervised. However, the power outage may have *damaged the electronic oven control* by hitting it with a current surge when the power was restored. THIS IS COMMON and why I always encourage my customers to purchase a "whole house surge protector" for between 60 and 100.00. It is some of the best money you can spend to protect your house--current surges aren't covered by warranties or most protection agreements.
Aug 30, 2015 | Kitchen Ranges
The lock symbol is showing but the door can open and no functions on the oven will work apart from the clock
This is the keypad lock (symbol looks like a padlock?). Find the button that has a padlock symbol near it, hold down for 3 seconds, should unlock your keypad. This should be described in your user manual if not indicated on the touchpad.
Aug 28, 2015 | Ovens
How to unlock the samsung microwave
Setting the Child Protection Lock
You can lock your microwave oven so it can't be used by unsupervised
1 Press the My Choice Button and the 5 button at the same time for
3 seconds.
The display shows : CHILD LOCK ON.
2 The display returns to the time of day.
At this point, the microwave oven cannot be used until it is unlocked. To
unlock it, repeat steps 1-2 above.
May 19, 2014 | Samsung SMH7178STD Microwave Oven
My Neff oven is displaying the locked "key" symbol...does anyone know how to unlock please?
Locking the oven:
Using the main oven function selector, switch 3 x in
rapid succession from the 'off' position to the
oven light function and back again.
- s - is displayed.
The oven cannot be unintentionally
switched on, e.g. by children.
To release the oven, switch 3 x from
the 'off' position to the oven light.
- s - goes out.
Mar 21, 2013 | Neff B1641 Single circotherm super...
Kenmore oven 790 model number, door locked, won't open
do you have a button with a small padlock symbol?
yes hold for 10 seconds you have start button? press and hold for 5 seconds about a clear/off press and hold for a full 3 seconds.
Sorry I'm at home and the teck guides are not here. So I gave it what I know from memory.
last but not least try turning off the breaker to it for a minute.
Hope this helps a little.
Feb 02, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Jun 28, 2011 | General Electric WCVH6800J Front Load...
The door is locked and will not open display says door locked been that way 3 days
Press and hold the oven lock button for approximately three seconds to turn off the oven lock. The oven lock button has a symbol of a padlock on it. You will hear a beep when the oven lock is turned off. You can now open the oven door and operate the oven as normal
Mar 18, 2011 | Frigidaire 30" Self-Cleaning Drop-In...
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Mar 04, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Viking Washing Machines Experts
Eric Taylor
Bill Boyd
Are you a Viking Washing Machine Expert? Answer questions, earn points and help others
