Question about Pool & Spa
MY HOT TUB WAS READING ICE A FEW MONTHS AGO NOW ITS READING DRY I USED A VAX HOOVER DOWN THE FILTER COULD I HAVE CAUSED A PROBLEM
    Habit-Forming:
  • 77 Answers
ICE is an issue with the cold water temperature. I'm guessing that you filled the spa with cold water, or turned the spa off and the water cooled right down. In ICE mode, the spa turns on the pumps and keeps running until it's satisfied that the water is not going to freeze, this can take some time.
DRY is an error that occurs when there's insufficient water in the heater, or a lack of water flow through the heater. This is commonly caused by either an air lock, a low water level, or a problem with the pump.
Is the pump circulating the water through the heater as per usual? If not, can you hear the pump running? If the pump is running but there's no water flow then suspect an air lock.
To remove an air lock, you can slightly loosen the pump union, or heater union to release air from within the system, much like when you have to bleed a radiator. As soon as water starts to come out of the union tighten it again. If you have an air lock you should hear the air escaping from the union prior to the water starting to leak out. If you heard air, that's great, try the spa again.
Posted on Apr 28, 2017
Vax co uk support
There are a number of possibilities. I have this appliance and I'm not a fan of it!
  1. Check the water filter isn't void, which is behind the main water tank at the front. It should have a sandy colour to it and if it is low or discoloured, then it requires to be replaced.
  2. Fill the water tank with water and the back tank (if fitted) with clear "white" vinegar and switch on. If there is only one tank fill half with water and vinegar. Then press the trigger on the handle. If nothing comes out, You will need to buy a new water limescale filter which can be purchased from Vax UK.
Oct 31, 2013 | Vacuums
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
Manual for vax 121 wet & dry hoover
I need a VAX wet/dry vacuum model 221-07 manual.
Apr 28, 2011 | VAX Appliances V037 Stick Wet/Dry Vacuum
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
GE TBX22ZA refrig. automatic ice maker stopped making ice. I replaced the first ice maker when it stopped working with one I found at a thrift store that was still in it's original box, never used. The...
sounds like the water inlet valve/solenoid may be bad. I've had some to work awhile then quit. It could be trash inside of the inlet valve. If it has a water filter on the frig try changing it also. But try the solenoid first by turning your freezer section thermostat to its highest reading to for 24hrs.to see if the solenoid is going to work.
Dec 15, 2009 | GE Refrigerators
Dryer gets hot but doesn't dry well
Restricted air flow...either vent or wheel that moves the air. Try taking hose off of where it goes outside and just let it run like that and see if clothes dry faster. If so you need vent cleaned.
Oct 06, 2017 | Hoover HWF5513E Front Load
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Dec 28, 2008 | Home
Ice maker hooked up for the first time doesn't work.
Usually it is prudent to unplug the fridge. Yes there may have been water in the line, You could allow the freezer to warm slowly for a few hours, however a warm (not hot) hair dryer will do the job well. PS I do have all 4 refrigeration licenses. Also is the water filter connected and clean, are the solenoids clicking when requested?
Apr 21, 2008 | Samsung RB215LASH
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
