Question about Refrigerators
Our sink water dispenser is running while in the off position!
    Top Expert:
  • Refrigerators Master
  • 12,744 Answers
Need to replace or rebuild the valve
Posted on Apr 17, 2017
Testimonial: "Is that something that a novic can do or should we just replace the unit."
  • john h Apr 17, 2017
    depending on unit and if water shut off valve holds --some units you can change cartridge easily others whole unit needs to be replaced --the following links can assist on what to expect in working with a dispenserhttps://video.search.yahoo.com/yhs/searc...
Howto repair refrigerator water dispenser
There is an electric water valve, usually at the lower back of the appliance which would appear to be stuck open and would need to be replaced OR the switch in the dispenser area is stuck in the closed position. Try disconnecting the wiring to the valve and if that stops it then most likely the dispenser switch is defective, If not then the valve is likely stuck open. There should also be a small valve in the water supply line, under a sink or etc. that you can shut off to stop the water flow with until you get the other problem daiagnosed and fixed.
Sep 08, 2014 | Hotpoint Refrigerators
Just replaced old softner w/new whirlpool 40,000. Hooked up correctly, regenerated w/ 6 tblsp bleach before use, tested/set hardness, Water is not soft....why?
Is the "bypass valve" in the correct position. I would suggest flushing the water heater at the boiler drain, bottom of tank to assure soft water in WH. Make sure there is salt in brine tank and manually regenerate the softener 3 days in a row. Retest water.
RJ
Sep 22, 2013 | Whirlpool Water Dispensing & Filtration
Mildew tasting water from water dispenser
Try running dome bleach through the dispenser. Might have a build up in the outlet line, after the filter.
Dec 26, 2017 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Icemaker dispenser mechanism stuck on running will not stop
shut off water valve under sink or ...the water vlave is stuck. See if ou can remove th ice maker and let it defrost.
Jan 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water smells in my hot water dispenser
There usually is an anode rod in a water heater that is there to attract the lime from the water. This helps prevent lime build up in the bottom of the tank and makes it last longer. However, the downside of this is the sulfur smell that comes as a result of the anodization (chemical) process. You could remove the rod and plug the hole in the heater to eliminate the smell. You'd give up some length of service as a result.
Sep 07, 2009 | Buck IN-SINK-ERATOR HOT ONLY WATER...
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool ED22PE refrigerator in-door water dispenser very slow
remove the saddle clamp that some idiot put on the supply line under your sink and splice in a real "T" with a real cutoff. hopefully the saddle clamp is past your main valve and not before it or you'll have to turn off all your water first.
Jun 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Mar 22, 2009 | Kenmore 43142 Front Load Washer
No water flow to ice maker
Two possible answers on this one. The water control valve for the ice maker is defective or the switches inside the front of ice maker are stuck.
Please send the model number listed for your refrigerator so I can help you find the ice maker switches and parts break down for your refrigerator. Below is my website address.
http://servicepartstec.blogspot.com/
Let me know if I can help you more, Thanks Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
