Question about EdgeStar AP450Z Portable Air Conditioner
Unit starts for 2 seconds then shuts off automatically
Yesterday my unit was leaking a little bit of water but was running fine. When I came in this morning the reset button on the plug had tripped and there was a big puddle of water on the office floor coming from the bottom of the unit. When I reset it, the unit will only start for about 2 seconds then shut off again.
  • 248 Answers
Did you empty the water out of the Water Tray?
Posted on Jul 25, 2009
The car will roll over just fine but will not start. Yesterday when i started it it started fine and shut off after it ran for about 2 minutes. Now it wont start.
The first thing i would do is to check and see if its a fuel problem, try sparying starting fluid into throtle, when spraying have aomeone hold pedal to floor then spray for about 2 seconds then have them release the gas pedal reinstall cover and then try to start, if it starts and runs for a few seconds then we know its a fuel problem and mostlikely its going to be a fuelpump, a little trick i do to test the pump is to have someone crank the engine while i beat the bottom of the tank with a rubber hammer and if it starts then the pump is bad, but always make sure to check wiring and connections going to pump. hope this helps,
Nov 05, 2010 | 1995 Pontiac Grand Am
I have a Briggs and Stratton 7000 watt propane generator. When running this morning after two hours, it quit. It starts back up for about three seconds or so then quits again. I put a new tank on...
does this engine have a low oil shutdown unit on it
if so check the oil level an top it up it could be interupting ignition
be sure your tanks are full and connections are good and tight
brush soapy water around connections to see if any have a leak
if not oil level shutdown , then sounds like a fuel problem
suggest have a gas serviceman take a look
these units can be tricky to solve
Aug 11, 2010 | Briggs & Stratton 15,000 Watt Home Standby...
Auto shut off comes on instantly
TURN UNIT OFF.. MAKE SURE DEHUMIDIFIER HAS NOT BEEN RUN FOR AT LEAST FIFTEEN MINUTES... TAKE BUCKET OUT... HOLD IN THE BUTTON THAT THE FLOAT IN THE BUCKET PUSHES ON.. THEN TURN ON THE UNIT.. DO NOT LET GO OF THE BUTTON EVEN A LITTLE BIT IF YOU DO YOU WILL HAVE TO WAIT FIFTEEN MINUTES AND TRY AGAIN.. IF UNIT WORKS THEN YOUR FLOAT IN THE BUCKET IS THE PROBLEM...
May 07, 2010 | Goldstar DH304 Dehumidifier
02 taurus won't move
Torque converter is locking up, common for this model. My wife's is doing the same, just changed filter, fluid, and added Lucas trans fix. Hope this works for a little bit, 2000-2500 to fix this if not.
Jul 10, 2009 | 2002 Ford Taurus
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Brake booster
taiman, It sounds like you have a vacum leak. Does the engine idle a little rough and smooth out when you accelerate? Try this little test, get a empty spray bottle, fill it with warm water, the add one tablespoon of dishwashing liquid, put the sprayer in and shake it up, then run the engine for a bit and shut it off and start spraying the solution in the area of your noise and when you hit it with the spray the noise will stop or change for a second. That will show you where the leak is and all you will have to do is repair it. Good Luck. quicbric (the volvo man)
Jul 06, 2008 | 1989 Toyota Pickup SR5
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
EdgeStar AP450Z Portable Air Conditioner Logo
159 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
