Question about Miscellaneous
Lights are dim on crosley cr17 - Miscellaneous
    Master:
  • 923 Answers
I do not doubt it. But is it normal? If not, how is the voltage, and how is the resistance of the wiring? I'm betting it's bad connections!
Posted on Apr 20, 2017
Gmc envoy bright lights work dim lights will not work
Your circuit lights may be bright or dim according to how your electrical system was set up. It may dim when lights are off and get bright when lights are on. ------------------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 24, 2012 | Buick LaCrosse Cars & Trucks
Crosley gas dryer
Reset the household circuit breaker and then see if you have any audible beeps or flashing lights for an error code
Jul 31, 2012 | Crosley CDG6000 Gas Dryer
No power is there a fuse?
Yes! it may have a fuse, or the power transformer sometimes has a built in thermal fuse that will open causing the unit to go silent, unplug and remove back, [few screws] look for a fuse near a power transfomer and replace with same rating, if none can be found the power transformer is probably open.
Jun 23, 2012 | Crosley iJuke (CR17) Shelf System
The lights are not working, what do I do?
you can replace that with the same wattage rating and the same voltage rating.
Jun 08, 2010 | Crosley iJuke (CR17) Shelf System
The power went out now it won't turn on.
Look for a fuse or reset on the back of the unit. Check the manaul for their location. You may want to remove the case to check fuses mounted on the board itself. When the power went out something blew. Hopefully it was a fuse. I assume you have tried it at a few outlets already...
Jan 13, 2010 | Crosley iJuke (CR17) Shelf System
Fluid in bubble tubes
The same thing happened to my ijuke the fluid just disappeared. I called crosley three weeks ago the person I talked to said the service department would call me back.I am still waiting...I talked to my sister, she bought an ijuke at target the same day I bought mine. she said that she had her ijuke lights on and the fluid just started squirting out of the top of the tube by the silver medallion and that everywhere the fluid touched it melted the plastic.
Jan 20, 2008 | Crosley iJuke (CR17) Shelf System
Dehumidifer - Working??? Not Sure.
if you can verify that the compressor is still active (is there a noticeable hum or buzz and / or do the room lights slightly dim during power on?) then the most likely problem is a loss of freon. if the compressor never turns on, then a faulty humidistat is likely...an electrician can run a test of this by "jumpering it out" to force on the compressor motor.
May 20, 2007 | Crosley 40-pint Dehumidifier
Open Questions:
Miscellaneous Logo
21 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
