Question about Moen Plumbing
Our Moen faucet csmevwithnacsprayer assembly. Thevsprayer head is broken. Whrrevcannwe getbavreplacement?
    Top Expert:
  • 12,650 Answers
Go to moen online site or a store that carries moen and order replacement
Posted on Apr 17, 2017
  • 2,709 Answers
General Plumbing supply... ACE is the place... True Value.. Orchard Supply, Home Depot... and at building Supply tores... AMAZON & eBay... to name a few.
Carnac the Magnificent
How t fix moen kitchen faucet sprayer
Moen Spray Diverter Repair
First, remove head and soak in vinegar. Use toothbrush to remove scale. If this fixes your problem, ignore the following.
To repair your Moen sprayer, first pick up Moen part # 91192 diverter and a Moen #117 spout o-ring set. Remove the cap on handle, remove the screw on the interior cap and remove handle. Your spout can now be removed by pulling it straight up. Here is a pic of the part. Slide the diverter up and off the faucet post. Remove the two o-rings from the post and install only one large one and one small one onto post making sure to grease them with the silicone provided. The other small o-ring is for faucets without the spray. Discard it. Slide the new diverter down onto the post and reassemble the spout and handle assemblies. Make sure to properly engage the flat on the handle into the groove on the retainer nut when reinstalling handle..
Aug 21, 2017 | Moen Plumbing
HOW TO FIX MOEN KITCHEN FAUCET SIDE SPRAYER CLOG
If it is simply clogged, soak the head in vinegar for an hour and use a brush to clean the scale from the spray head.
Instructions if your sprayer has failed:
To repair your moen sprayer, first pick up Moen part # 91192 diverter and a Moen #117 spout o-ring set. Remove the cap on handle, remove the screw on the interior cap and remove handle. Your spout can now be removed by pulling it straight up. Here is a pic of the part. Slide the diverter up and off the faucet post. Remove the two o-rings from the post and install only one large one and one small one onto post making sure to grease them with the silicone provided.The other small oring is for faucets without the spray. Discard it. Slide the new divertor down onto the post and reassemble the spout and handle assemblies. Make sure to properly engage the flat on the handle into the groove on the retainer nut when reinstalling.
When I turn on the cold or hot water sink faucet water leaks out from the top of the cold water faucet . I took the outer casking off and can not figure how to remove the stem. I removed the ring but...
if you have the ring removed, screw the handle back on and pull up on it,, your leak is probably due to a worn , torn , "O" ring,, and Moen parts are found at most hardware stores ,, ( including Home depot , and Lowes) On Moen faucets , Look for the dent in the flange that squares off,, where that square is on the ring, is where the retainer ring is that holds the faucet in place ..its a "C" clip with a head on it, remove this ring and the assembly should come out , be sure and use plumbers grease when replacing the O rings,, they last much longer that way
May 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Leaky faucet
most taps have either a flat head screwdriver or a allen key lock nut behind the hot and cold indicator
Jul 13, 2010 | Moen Chateau, One-Handle Lavatory Faucet...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Our faucet after working for years now produces very low pressure when turned to hot. Any ideas?
If you have hard water, you probably have lime built up in the head.
Take the shower head off and soak in vinigar or CLR, and re-assemble.
HTH,
Mike...
Dec 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen one handle kitchen faucet very low water stream
if the pressure is good with the head off then you can probably get a new head for it u shouldn't have to change the cartrige. it sounds like the head is clogged so plastic pieces in the head to help save water "water savers" it is hard to clean them i would try changing the head u should be able to find on for a moen, u buy for looks u buy it for life. take the old head with u when u go to buy a new one so they can match it up to the right one.if you can't find it and a lowes or home deptm try a plumbing supply house
Mar 08, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Plumbing Logo
37 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
