Question about Konica Minolta Office Equipment & Supplies
My konica minolta bizhub 164, when the machine is starting and warmingup after that the machine sound like main motor mulfunction, however, the main motor is clear. How will i do plis
  • Konica Minolta Master
  • 6,696 Answers
Does it display a malfunction code if so what
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 06, 2017
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
  • 158 Answers
SOURCE: konica minolta bizhub 162 have error C0000(main
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Posted on Nov 30, 2009
Testimonial: "yes this is right ! i figer out the problem - it was in development unit! tNx"
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How to replace the drum in konica minota bizhub 184/164
It looks like a service part rather than something you can change yourself as it may be buried in the guts of the machine. Not saying that it isn't possible, but does the machine hinge up at all?
Sep 30, 2014 | Konica Minolta - bizhub 20 Laser...
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
Bizhub 164 error code c-5102
Code
C5102
Description
Main motor malfunction
- The main motor (M1) lock signal remains HIGH for a continuous 1-sec. a period at any time 1 sec. after the main motor has started turning.
Remedy
1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary.
2 Check M1 for correct drive coupling and correct as necessary.
3 M1 operation check.
4 Change PRCB.
5 Change DCPU.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Oct 03, 2013 | Konica Minolta bizhub C250 All-In-One...
How to solve error code c2351 in konica-minolta bizhub 164
Suction Fan motor failure fan located right side of machine from the front. Check vent can air and remove cover check fan and or replace worse case the board
Apr 30, 2013 | Konica Minolta bizhub Office Equipment &...
How to solve error code C2351 in konica minolta bizhub 164
Suction fan motor malfunction power off the on wait ten seconds between. check all the vents on the machine remove the covers where they are located and power on the machine check to see if they turn use can air to clean or get them replaced.
Apr 30, 2013 | Minolta bizhub 200 All-In-One Printer
Konical minolta bizhub 164 mahine service call c2558
machine trouble sevice call [c2558] wat a problam in konica minolta bizhub 164 printer
Jun 02, 2012 | Konica Minolta bizhub C250 All-In-One...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
43 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
