Question about Garden
How to remove a Mountfield 25 circa 1960/70 ride on mower steering wheel and or steering column assembly?
defadad
  • 351 Answers
SOURCE: I need help to find how to repair steering assembly Part broken
should be an metal arm under the front of the mower with a swivel ball on each end, if the ball has popped out of the socket it sits in you will need a new arm or maybe 2 new ball swivels, the actual balls are held onto the steering arm by a nut which you can undo to remove the old ball and replace it with the new ones
Hope this helps
Posted on May 11, 2009
warlock61
  • 659 Answers
SOURCE: R&R Steering Wheel Assembly and/or Steering Column Assembly
if you disconnect the battery and let it sit awhile this will disable the airbag.
Posted on May 16, 2009
  • 376 Answers
SOURCE: We have a Sears Craftsman riding mower 917.258671
The steering assembly your mower has is very difficult to repair. Thank God they no longer make that type. Forget about trying to tighten that screw, it won't solve your problem anyway. Believe me, you should take it to a repair shop.
Posted on Nov 05, 2009
  • 150 Answers
SOURCE: John deere 68 riding mower steering column won't
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
  • 6468 Answers
SOURCE: Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Posted on Jun 16, 2012
Steering wheel turns one quarter before wheels turn-how do I fix-thanks
Need to check out the linkage between the steering wheel and the front wheel assembly.
Feb 25, 2016 | Garden
Mtd riding lawn mower front wheels turn different ways
you have assembled something incorrectly. Have a look and see where the linkage is going, I am guessing that you have put them wrongly on the bar that is moved by the steering column.
Sep 10, 2015 | Mtd Garden
How to remove the ignition lock cylinder from a 93 geo storm
is the lock assembly in the car or out?
there are 2 jobs here, removing the assembly
and after that, attacking the lock it self.???????
any lock smith can rebuild the lock, proper
it has pins that are pressed out.
it can even be rekeyed.
the remove assembly is covered in the FSM, no books?
alldata.com covers that.
it really is an Isuzu. impulse.
my guess is its job 1, assembly out.
so toss coin lands on job1
(on most cars, steering wheel must be removed)
once that is done, its obvious from there, right? that clamp there with the antitamper screws? then must be removed. and replaced new..
a rare car , and even more one that runs....
here is the online FSM answer
  1. Remove the negative battery cable.
  2. Remove the steering wheel.
  3. Remove the combination switch assembly.
  4. Turn the key to the OFFposition, depress the retaining pin and remove the ignition lock cylinder from the switch.
  5. Disconnect the electrical connector from the ignition switch.
  6. Remove the snapring and spacer collar from the steering shaft.
  7. Disconnect the back drive cable from the ignition switch.
  8. Remove the ignition switch bolts and the ignition switch from the steering column.
now back in?
  1. Install the ignition switch to the steering column and tighten the bolts.
  2. Connect the back drive cable to the ignition switch.
  3. Install the spacer collar and the snapring to the steering shaft.
  4. Connect the electrical connector to the ignition switch.
  5. Install the lock cylinder into the switch.
  6. Install the turn signal switch screws and the turn signal switch.
  7. Install the four screws and the coil assembly to the turn signal switch.
  8. Connect the coil assembly wiring harness to the turn signal switch.
  9. Install the two piece steering column cover and the two piece steering column cover screws.
  10. Raise the steering column and install the upper steering column mounting bolts. Tighten the bolts to 18 ft. lbs. (24 Nm).
  11. Install the left lower dash trim panel and tighten the lower dash trim panel screws.
  12. Install the lap air deflector and tighten the lap air deflector screws.
  13. Install the knee pad assembly and tighten the five screws, the bolt and the nut attaching the assembly.
  14. Install the engine hood opener cable.
  15. Install the engine hood opener and tighten the two screws.
  16. Connect the electrical connector to the cigar lighter bezel and install the bezel.
  17. Connect the electrical connector to the left switch bezel and install the bezel.
  18. Install the steering wheel.
  19. Connect the negative battery terminal to the battery.
that?
Oct 08, 2014 | 1993 Geo Storm
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Sep 27, 2010 | John Deere Garden
Steering wheel gear is stripped
Please for the love of god tell me you have an answer to this, same problem, sooo angry, hit me up at reid72@aol.com pleeeesee
Jul 15, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Now to install igintion switch
Removal & Installation The ignition switch or warning switch can be replaced without removing the steering lock assembly. The ignition switch is on the back of the assembly and the warning switch on the side.
  1. Disconnect the negative battery cable and insulate the terminal end.
CAUTION The air bag system must be disarmed before removing the steering wheel. Failure to do so may cause accidental deployment, property damage or personal injury.
  1. Remove the steering wheel and the steering column upper and lower covers.
  2. Remove the spiral cable assembly.
View of the steering lock and ignition switch assembly
  1. Remove the combination switch from the steering column.
  2. Remove steering column support nuts and lower the steering column.
  3. Disconnect the ignition switch wiring and interlock cable (if equipped).
  4. Remove the bolts that secure the steering lock and remove steering lock assembly.
To install:
  1. Install the steering lock assembly and secure with new shear type bolts.
  2. Connect the ignition switch wiring harness and the interlock cable.
  3. Raise the steering column and secure with mounting nuts.
  4. Install the spiral cable assembly.
  5. Install the combination switch, steering column covers, and the steering wheel.
  6. Connect the negative battery cable and enable the air bag system.
May 23, 2010 | 1997 Nissan Maxima
We have a Sears Craftsman riding mower 917.258671 the steering wheel has a lot of play in it and has turned a full half turn when going straight. In other words the top of the steering wheel is at the...
Oct 03, 2009 | Craftsman Garden
Hope this helps
Apr 25, 2009 | Garden
Hi Guys,got mower mountfield m4 circa 1988, can find no info whatever, please help,m Rgds Meil,
i need a grass catcher for a mountfield express can i use one from a different model
Feb 28, 2009 | Garden
How to take off steering wheel.
  1. Disconnect the negative battery cable.
If necessary for access or service remove the steering wheel. Except for on 1967-69 simulated wood wheels, be sure to use a steering wheel puller.
  1. Remove the nut/bolt from the upper intermediate shaft coupling, then separate the coupling from the lower end of the steering column.
  2. If equipped with a column mounted shifter, disconnect the transmission control linkage from the column shift tube levers.
  3. If equipped with a floor shifter, disconnect the backdrive linkage.
  4. Disengage all of the electrical connectors from the steering column assembly.
  5. Remove the floor pan cover-to-floor screws, the floor seal, and the cover.
  6. Remove the steering column bracket-to-instrument panel nuts and carefully lower the column. If equipped with an automatic transmission, disconnect the shift position indictor pointer.
Once the steering column has been removed from the vehicle, be careful not to drop it (especially on it's end), lean on it or damage it in any way; the column is very susceptible to damage.
  1. Remove the column from the vehicle.
To install:
  1. Position the steering column in the vehicle. If equipped with an automatic transmission, connect the shift position indicator pointer.
  2. Raise the column into position, then install the column bracket-to-instrument panel nuts and tighten to 25 ft. lbs. (34 Nm).
  3. Install the floor pan seal and cover, then secure using the retaining screws.
  4. Engage all of the electrical connectors to the steering column assembly.
  5. If equipped with a floor shifter, connect the backdrive linkage.
  6. If equipped with a column mounted shifter, connect the transmission control linkage to the column shift tube levers.
  7. Connect the intermediate shaft coupling to the lower end of the steering column, then secure using the nut/bolt.
  8. If removed for access or service, align the matchmarks and install the steering wheel.
  9. Connect the negative battery cable.
Good luck..
Nov 23, 2008 | 1986 Chevrolet El Camino
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
