Question about Ovens
Lre 6325 with multiple buttons on touch pad not working. cleaned ribbon but did not work
Powerman
  • 68 Answers
SOURCE: Power surge, and pad won't work
This may be related to the F7 problem. I have a post on this site.
Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this fix with over 1400 folks and most report success. I hope that it works for you too.
Posted on Nov 20, 2007
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
SOURCE: touch pad does not work and flashed FO
this happened to us when we had a power surge. The following instructions fixed our oven!! however, the next month we experienced another power outage and it did not work and the Sears repair man said we need to replace the Oven Control ($300) and the Sub Panel ($300) good luck! Joanne
FO CODE ON STOVE. HOW TO RESOLVE:
  1. Turn power off to the oven by flipping the circuit breakers off to oven for a few minutes then power back up.
  2. Press Bake and Broil keys simultaneously.
  3. Press Hour Down and Minute Down keys simultaneously for 5 seconds.
  4. Wait approximately 20 seconds after the time of day is displayed.
  5. Press the Temp Up and Minute Up keys simultaneously.
  6. The control will briefly go blank, briefly display all LED segments, briefly display LOC REF, then display all segments for 30 seconds, and finally display LOC REF.
  7. Press Hour Down and Minute Up keys simultaneously.
  8. The control will then display the time of day and operate.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q126596
Posted on Aug 20, 2009
  • 523 Answers
SOURCE: Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
Posted on May 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Exactly the same problem. My oven is 11 yrs old instead of 10
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
BAKE & CLOCK BUTTONS DO NOT REGISTER WHEN PUSHED- CLEAN & BROIL BUTTONS ARE REGISTERING
If your oven is a touch pad model then the pads are bad. the touch pad assembly will need replacing. Sometimes you can remove the ribbon cable and reinsert it. It sometimes will make them work but not very often. Make sure the power is off first. Remove the control panel. You will see the ribbon cable. There will be small tabs on each side of the connector plug carefully unclip these and remove the cable and reinsert it. Be prepared to replace the panel.
Nov 25, 2013 | Whirlpool RBS275PD Electric Single Oven
F2 e1 error code kitchenaid
Touch pads are notorious for going bad. You can pull the ribbon cable off and gently clean the contacts with a pencil eraser. If this soesn't fix the problem then the touch pad is more than likely the culprit.
Oct 24, 2013 | Ovens
Part of maytag oven touch pad not working
When certain buttons don't work on the touchpad sometimes it can be resolved by making sure that the ribbon cable of the touchpad fits tight into the control board,and also the end of that ribbon cable could be cleaned with a pencil eraser. If neither of those work the touchpad would need to be replaced.
GENE
Oct 10, 2011 | Ovens
Getting F1 error message
F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself.
Mar 11, 2010 | Ovens
I receive an F1 error notice when I cancel the bake setting.
Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
if you are handy you can remove control board ribbon clean in and replace..
Sep 27, 2009 | Jenn-Air Ovens
Jul 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven having F11
Hello, F11 is definitely a key stuck failure and I didn't require any parts to fix this.
The cause of the problem is an over abundant use of double sided tape at the factory. I suspect that either heat or continued use of certain buttons causes the glue to weep into the button/contact pad causing the button to stick to the contact. On powering up our range showed PF and if you waited 10-15 secs without touching any keys F11 would display and and there was continuous beeping. I verified this was the case by removing the upper rear panel of the stove and disconnecting the keypad connector from the upper left of the lockout board. Then on powering up our range simply sat there showing PF. Of course you can't get past this with the keyboard disconnected anyway.
The fix--- to make repair easier I removed the glass panel to which the keypad is stuck from the range. Pull off the burner knobs and you will find plastic nuts holding the glass panel to the metal housing. Remove the plastic nuts (make sure you let the keyboard connector go first by pulling the connector lock -small tabs on either side of the keyboard ribbon - towards you about 1/8". The ribbon cable will then slide right out.) Use a razor blade to gently work your way around the plastic trim bezel and remove the bezel. The keypad actually consists of three plastic sheets sandwiched together. You only need to remove the top 2 layers. Layer 1 is the printed keypad and layer 2 is the contact pad.
You have to be careful in all this or you may crease or damage a panel. I started the edge with a razor blade and then stuck in the edge of a spatula. The idea is not to slide the spatula in but rather to insert it a small amount and lift. Slide it in a little more and lift. Just have a little patience and don't simply try and slide the spatula in or you may scrape the keypad and/or contact pad. While I suppose the more AR of us would then have to clean all the double sided tape off I simply cleaned up the keypads and matching contact pads. I stuck the whole thing back together and reattached the keyboard ribbon cable (hold it in place while pushing in the cable lock mentioned above. If you aren't too squeamish you can test the keypad while you have everything apart as follows: Connect the contact pad (this is the part with the ribbon cable attached) to the lockout board. Power up the stove. At PF touch one of the keypads to the stop/cancel contact pad. The PF should be cleared and you should be able to operate the oven by touching one of the keypads to appropriate contact pads.
Thanks
Jul 17, 2009 | Frigidaire FEB27S5A Electric Single Oven
Touch Pad issues JT952-30
Hi richard..
the ribbon connector that connects the touch pad to the control may not be correctly connected. you may try to remove and reconnect it... be sure to have the power to it turned off..if the is not the solution the replace the touch pad...
Aug 16, 2008 | GE Profile JT952 Electric Double Oven
Ovens Logo
57 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
