Error code c3500 and error code f000 appears on taskaalfa 1800 .remedy?
  • 202 Answers
SOURCE: SONY uvw 1800 Error Code 02-454
The unit powers on, the drum shows only 0005 hours on it, but the display says it has an "Error 02-454" Error Code, and says "REC Inhibit", and it will not accept a tape. When this unit is powered on it shows error code 02-454 which is:
S-REEL FG COULD NOT BE DETECTED WHILE IN FF/REW MODE.
You can cross-reference this error code at the following web site:
http://www.johnjvsvisual.pwp.blueyonder.co.uk/UVW1600-1800%20error%20codes.pdf
From what I’ve been told this is a very easy fix for someone that knows how to work on these. It is a very clean machine, inside and out, and I am sure it is well worth getting serviced and put back in use
Posted on Aug 02, 2008
kornho
  • 781 Answers
SOURCE: error code on booting
it may be a memory board error.. you may have to replace the motherboard
Posted on Sep 20, 2008
SOURCE: Call Service F000 error
F000 is a panel communication error... update firmware... firmware as far as i know isnt available to the public... contact kyocera
Posted on Jan 15, 2009
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
SOURCE: Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Posted on May 12, 2009
I HAVE AN ECOSYS FS- 6525MFP KYOCERA COPIER PRINTER. IT DISPLAYS ERROR CODE F000 WHAT CAN I DO TO RESOLVE THE PROBLEM?
Code
F000
Description
Main PWB - operation panel PWB communication error
Causes
Defective main PWB.
Defective operation panel PWB
PWB = printed write board
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=FS6525MFP&code=F000
Nov 07, 2017 | Kyocera Office Equipment & Supplies
Hi Fixya,can you please help us how to fix kyocera taskalfa 1800 call service f000
Heat code. You will need to reset in service mode.1087 1087 function find reset fixing assembly and activate. If it comes back you have a bad bulb or a bad thermistor. Could be a thermal switch . It's the fuser assembly.
Feb 12, 2017 | Kyocera Office Equipment & Supplies
Receiving error code C-E301
I just found this on the knowledge base it refers to this code when the hdd is replaced and internal data is different it may be a faulty hdd but there is a firmware in reference to this code.
Error C-E301 occurs for mismatching in the internal data as HDD is changed.
C-ED01 will be displayed as the mismatch in the internal data occurs as HDD is changed.
HDD Format will be necessary when this trouble is displayed.
firmware: A2X00Y0-F000-GPQ-65.exe
Mar 31, 2014 | Konica Minolta Bizhub C454 Color Copier
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Every time I turn it on this message appears,
fuser unit error. use 10871087 to get into service mode. go up to U163 to reset error code. If it happens again , you will need to repaclace or rebuild the fuser.
Oct 19, 2009 | Office Equipment & Supplies
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
Error code on booting
Sep 16, 2008 | IBM NetVista PC Desktop
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
k24674
jasbo
jasbo
