For Risk cz 100 lists of maintaining p-53 ,-31 display errors corrections
Riso cz 100 showing paper jam error J08
Take it apart and check to see that no paper not even a sliver is in the area of the sensor.
Nov 16, 2016 | Office Equipment & Supplies
Hello, is there a firmware available for my digital camera?
Why would you need firmware? when the camera does to work 100% correct, you can't replace the software, without the risk to lose all functionality of the camera. When a serious error is in the software, every firm will inform all registered users there is an update.
Mar 07, 2015 | Cameras
Check setting error in d-04-560 Riso CZ 180
saya membutuhkan informasi dimana di surabaya service mesin cetak riso black cz 180 ?
Feb 04, 2014 | Office Equipment & Supplies
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
Kodak easyshare M753 lens error 115 100
Here are some troubleshooting steps that you can try that may correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
Jan 26, 2013 | Kodak Easyshare M753 Digital Camera
What are 3 functions of syntax in command 'dir'
The syntax is the correct method of typing a command. The command must be entered in the correct order and spelling for the operating system to accept it. So : dir/w is correct But dir \w Is not..
dir/w will display the contents of the current directory, but in a wide format dir/p will display the contents of the current directory until your screen is full. You then press any key to scroll down the directory listing until you reach the end. dir will display the contents of the current directory with each directory item shown on a new line. you can use each of these switches together too.
dir/w/p will display the contents of the current directory in a wide format but the listing will pause when the screen is full. Pressing any key will scroll the listing down. A word to the wise. If you are not comfortable or have little or no experience with working in the DOS Command environment, DONT.... You can cause serious damage to a system simply by mistyping a command or using the wrong command. Do so at your own risk..
Feb 05, 2010 | Gateway GT5220 PC Desktop
Canon DVD burner DW-100 and HG10 burn issue
You can not have any MXP Files in your play list or in memory. The DW-100 Can not burn these files. Once you delete/remove the MXP Scenes from the the Camera the Burner will work fine.
Dec 13, 2009 | Canon DW 100 DVD-RW Burner
Error 77 display in the display
To get into maintainance menu:
Power off (remove cord).
Power on while pressing Menu/Enter Button.
Keep button pressed until boot process is finished.
Press 9 to get into maintainance
9 1 1 = print out configuration list
9 9  exit
If you find a way to reset the drum unit counter please post here.
In many cases the counter seems to shut off the machine although the drum unit is still fine.
Well, maybe they just want to sell new drum units.
Mar 28, 2009 | Brother FAX-8070P Plain Paper Laser
22 people viewed this question
k24674
jasbo
jasbo
