Question about Toshiba Televison & Video
Hi i have a Toshiba CT 8003 TV it switches on and flickers but no sound or picture
  • 298 Answers
SOURCE: No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Posted on Nov 22, 2007
  • 3 Answers
That problem is caused by the Y Sustainer board.
Posted on Apr 05, 2008
  • 73 Answers
SOURCE: Panasonic TV - no picture, but sound is ok
resolder flyback transformer contacts on the board, if doesn't help, replace flyback and horizontal output transistor
Posted on Oct 06, 2009
sonicboomele
  • 1557 Answers
SOURCE: how to replace on/off power switch on TEAC CT-M343 TV
the switches have a small spring that helps click the button to stay on or off its common for the spring to snap if you have another switch just pull it appart and replace as you undo it of not you can jam the switch on with a slide of paper or match stick then turn on off at wall or put a lighting switch in line with the power cord such as from a lamp
Posted on Apr 21, 2010
gopakumarg43
  • 75178 Answers
SOURCE: Toshiba lcd CT-90302
This is not the fault with remote control. It must be the fault with the TV. Check its main power regulator board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 27, 2012
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
How to reset a Toshiba TV Model CT-90233
Probably needs the caps replaced in the power supply but I would get an engineer to tackle this job unless your confident at soldering.
Sep 09, 2014 | Toshiba CT-90233 Remote Control
Nov 26, 2012 | Toshiba Ct-90302 Remote Control
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
Aug 23, 2009 | Toshiba 42HP95 Television
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Televison & Video Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
