Question about Samsung Refrigerators
How do I get my Samsung RSA1DTMG Freezer to dispense ice. It makes the ice OK but doesn't dispense it
  • 298 Answers
SOURCE: Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Posted on Nov 21, 2007
SOURCE: Ice dispenser only dispenses barely frozen wet ice.
We keep the freezer at 38 degrees.
Posted on Jun 14, 2008
SOURCE: Kitchen Aid Ice Maker will not dispense Ice
Ice will not force the hatch open.
Posted on Jan 22, 2009
SOURCE: Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Posted on Apr 10, 2009
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Manufacturer recall on door because the wiring was cut by use. Replaced free by certified repairman.
Posted on Sep 20, 2010
I have Samsung rfridgewith freezer on bottom. We replaced the the ice maker but but now it makes ice just won't dispense
try defrosting the ice dispenser portion of the unit, it might have ice buildup stopping the auger from functioning
Jul 13, 2017 | Samsung Refrigerators
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker stopped working, but used to work very well. During a course of a week, ice production kept slowing down to nothing. Test button on the side of the ice make unit does nothing. Unit is only a...
I had a similar problem with my Samsung fridge, my problem was the the ice holding unit had been taken out and not reinstalled correctly,
There is a rod on the rear of the tub and it has to be placed properly in the drive gear at the rear of the ice making housing so that it fits properly and smoothly.
If you still have a good water supply available at the door then the problem is probably what I just described, Good luck
Aug 27, 2011 | Samsung RF26VAB (25.5 cu. ft.)...
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
