I have cz100 Risk how can I solve p-53 display
My capsule reads D 53
D 53 (Tamsulosin hydrochloride 0.4 mg)
Pill with imprint D 53 is Green & Orange, Capsule-shape and has been identified as Tamsulosin hydrochloride 0.4 mg. It is supplied by Aurobindo Pharma Limited.
Tamsulosin is used in the treatment of benign prostatic hyperplasia; overactive bladder; ******* tract stones and belongs to the **** class antiadrenergic agents, peripherally acting. There is no proven risk in humans during pregnancy. Tamsulosin 0.4 mg is not a controlled substance under the Controlled Substance Act (CSA).
Dec 10, 2017 | Coffee Makers & Espresso Machines
How to fix Riso CZ100 error code h 101
1. Double click on ur start key to go zero on display panel. Machine will Ready to printgood luck
2. You need to input the value on the machine for the ink color the value is 1-black or 2-color
you need to go into service mode the go to 890 and input what color of ink the drum is weather its black or color and that should get rid of your issue
3. The machine either has "knock off" ink (generic) or "knock off" masters (generic) installed in the machine.
Try installing Genuine Riso ink and masters and the problem should be solved.
Apr 05, 2017 | Office Equipment & Supplies
How to repair Riso cz100/180 error code P15-218
this problem not solve paper not goin to scane
Jun 02, 2014 | Riso RZ220 Duplicator
Where do i hook the brown wire to clarion cz100
The brown wire is probably phone mute. You don't really need to attach it to anything for the radio to work.
Dec 04, 2011 | Clarion CZ100 Car CD MP3 Player
Error code P - 98 - 934 on RISO CZ100
You need to replace motherboard (P-98 error) of your printer the cost of it is to high, then I suggest value this repair or replace your printer.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | Riso RZ220 Duplicator
I Have A Clarion CZ100 On My Integra, I Put It Back On Yesterday Because My Car Came Out of The Shop. It Was Doing Fine Until Today, Turn On My Car and It Played, But When I Wanted To Change The Radio...
it's more likey the faceplate, and where it makes contacts with the unit. if you try applying pressure and moving the detachable faceplate on while attached and it turns on, there could be a cold solder/loose connection on the board.
Feb 06, 2011 | Clarion CZ100 Car CD MP3 Player
How to solve erow code in riso machine model cz100 the error code show that P-947 98
Hi
You need to replace motherboard of your printer
you better replace your printer
Pls vote me to keep me alive
Nov 25, 2010 | Office Equipment & Supplies
Installed cz100 radio sounds great, cd loads & reads but no sound???
are you using an amplifier? if so, it sounds like you are using the blue (antenna remote turn on) wire instead of the blue/white (amp remote turn on) to turn the amp on.
Nov 16, 2010 | Clarion CZ100 Car CD MP3 Player
Clarion CZ100 install ?
yellow battery
red accessory
black earth
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
Aug 10, 2010 | Clarion CZ100 Car CD MP3 Player
Hp 4si
Your post is correct that error 53 refers to bad memory board or at times defective SIMM only. Since you have replaced them and no change, you may want to try to do a Cold Reset of the printer. This is done by powering on the printer while holding down the GO or Online button. Additionally, you may want to check/reset your NVRAM settings which can be done manually through the Service Mode.
This page lists most of the HP Laser Printer error codes. This link displays most HP LaserJets - Cold Reset Instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | HP LaserJet 4si Printer
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
