Question about Plumbing
Washlet e200. When the washlet gets plugged in, the wand comes out and goes back in as usual. But it does not operate from either the remote or the side buttons.
The fan works. Any idea of the problem. Thank you.
  • 659 Answers
SOURCE: Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Posted on Apr 08, 2009
muralme
  • 20 Answers
SOURCE: Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
Posted on Jul 12, 2009
  • 151 Answers
SOURCE: had a new commode installed and now the washlet
check the GFCI outlet (ground fault circiut interupt) that the commode is plugged into there is two button on the outlet one is test and the other is the rest try pushing the rest button. If it kicks back off or doesnt take care of the problem call the installer.
Posted on Dec 24, 2009
  • 81 Answers
SOURCE: Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
Posted on Jun 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Toto Washlet doesn't work. I changed the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Little water pressure from wand. The pressure does increase and decreasefrom little to nothing and only from one hole.
Try removing tip on wand 9 out of 10 times sand or grit will plug spray orifice
Mar 27, 2017 | Toto Home
I need a Base Plate Template for my toto washlet c100
Wow I need one of those. Never even seen one before. Found a site that has spares luv.
Washlet C110
Nov 03, 2011 | Home
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
Jun 02, 2010 | Toto CST414M-51 Aquia Dual Flush Close...
Had a new commode installed and now the washlet toto won't work. what can I do to trouble shoot it
Dec 24, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
How does one replace the seat on a Toto Washlet model SW824?
two screw if you look in frent botim of tank that you flush normally plastic open and the seat will come off and you put back the new one the same way back
Aug 05, 2009 | Toto Washlet S400 for Power Gravity...
Toto Washlet weak
Jul 02, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
No water comes out of the wand
First, you must be sitting on it before it will work. Their should be a separate valve for the bidet function, be sure it is turned on. Also check that the seat is installed properly and the quick release "snaps" into place. These are the most common problems if they don't fix it let me know.
Please rate this solution-
Mar 19, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Plumbing Logo
37 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
