Question about Bosch Dryers
Cleaning pump on wtl5410 bosch dryer - Bosch Dryers
2 Suggested Answers
apart4u
  • 213 Answers
SOURCE: Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Dec 18, 2010 | Bosch Dryers
I have a Bosch Axxis wtl5410 . I have been doing a lot of laundry lately and it finally got to the point that the dryer was no longer working. I removed the bottom panel ;and pulled out the heat exchanger...
Hello, Welcome to FixYa.
There are a couple of scenarios which may prevent the dryer from starting with Bosch.
To save time and back and forth dialog, I`ll mention the most likely and what to do about it.
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
There is an auto shut off or emergency kill switch next to the motor which will prevent it to start in the event it was tripped for whatever reason.
It will look like this image below and all you need to do is push it to the right ( from the back )...
i.e.
If you`ve already taken the back of the dryer off to gain access you should have no problem. If you never have, it`ll take some time.
Either Scenario I alluded to ( the other would be resetting the hi-limit cut out, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below ) will require the removal of that panel so let me know if you require further assistance to do this.
i.e.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 06, 2010 | Bosch Electric Dryer
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Common faults -
May 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Pump fail
Have you actually checked the pump, normally they are just clogged with fluff and residue, they dont fail that often. Remove the side panel, the side where the drain container is. You will see the pump assembly at the bottom, remove the screw and top cover, then push the clip in to remove the pump unit, after removing the wiring plugs, the pump can be stripped and cleaned, clean the water chamber also which will be clogged. Hopefully it will work fine.
Mar 26, 2009 | Bosch Dryers
Pump fail
wow that is a fancy one. most of them simply have a catch basin you have to dump. Probably lint is topped up the pump. Open the pump clean out and get the gookus out of it.
Dec 15, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Bosch dryer
I had this problem for an axxis condensation WTL5410.
When starting dryer ligghts on front would cycle through normally as if dryer were running but dryer would not turn or get hot.
The problem was the door switch.  Push in the door switch activator on the bottom right of the dryer.  Push it hard a few times and try the dyer again.
doesnt sound like a great solution - but after 150$ and 2 service calls - it was what fixed it for us.
Jan 14, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
23 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
