Question about Lands Phones
Hi, How do I reprogram a current extension from an old employee's phone on each phone, to a new employee in a different office?
SOURCE: Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Posted on Apr 22, 2008
SOURCE: moved user, need to change extension at new desk for avaya 2420 phone
Have your system admin movethe extensions ports. You have a definity or S87xx series.....that is the only way.
Posted on Jun 14, 2008
SOURCE: Trying to change the name on a phone
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4
3.Press the top grey button (the set on the lower right hand side with the grey buttons closest together)
4. press the button under the one you just pushed until you get the desired name/ or the one with no name the same button as in number 3 (once only) the same button as in number 4 (2 times) you should get the name and a soft key button for change
7.type the name like a text message
8. once you filled it in hit the same button as in number 4.
9. hit release
Posted on Oct 25, 2008
SOURCE: Station (extension) names
From extension 10 or 11
Feature 00
Left intercom
Left intercom
Right intercom
enter the extension you want to modify
press the left intercom
Enter the name.
When finished, press feature 00 to exit programming.
Posted on Nov 20, 2008
SOURCE: changing employee name on extension
This has PDF file that will give instructions.
Also this link has more instructions:
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Posted on Mar 10, 2009
I cannot ring other phones in our office and my phone doesn't display when other employees are on the phone
Hi Kym,
It sounds like your phone might be a bit of a lone ranger! Try cloning someone else's phone settings to your phone and see if that solves the problem for you. You can do this by:
Feature **266344
Password: 266344
You should see Terminals and Sets. Press the Show button.
It should ask the for extension number, so enter the extension of someone whose phone is working properly.
Press Copy
It'll say "Copy SystemData" Change that so that it copies subscriber as well.
Press Next. It'll say Copy Single. Press Next
Enter your extension number when it says Copy to:
Once it has finished, hang up and give your phone a try once it has updated.
Jan 14, 2014 | Nortel T7316E 2-Line Corded Phone
How do I reprogram the buttons? Office personnel has changed and I would like to put some different numbers in speed dial.
On the set you wish to reprogram, press feature 00
press the button you want to program, enter in the phone number you want. if you want to program someones extension, after pressing the button you want to program press the right intercom and the persons extension number.
Dec 19, 2009 | AT&T Partner 18 Phone (315805B)
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
Need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Jun 16, 2009 | Panasonic Lands Phones
I have a Partner-18 and need to reset the password for a user
Delete the mailbox for this extension then re-create entire mailbox.
May 04, 2009 | Avaya Lucent Partner 616 Phone
Re: Question
Your phone can have 3 options, Ring all the time, Switch between Voice and Ring, or Voice all the time.
From your phone(s) press PROG 21 and press the ENTER soft key (3rd key). Now press the SEL (3rd key) until it says VOICE CALL then press ENTER and EXIT. If you set it to this mode, the AUTO ANS button won't work.
If you select TONE, the Auto Answe button will work, making the phone VOICE CALL when lit and ring when not.
If you select VOICE CALL DENY, the AUTO ANS button still won't work and get the pattern.
Oct 22, 2008 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
