Question about Cuisinart Microwave Ovens
I purchased a brand new Cuisinart microwave and it sounds so loud when its running. it heats up and works fine just a loud noise .Is this normal?
MicrowaveSvc
  • 9098 Answers
SOURCE: New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
Posted on Mar 29, 2007
  • 18 Answers
SOURCE: Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Posted on Jan 31, 2009
jsrock516
  • 5911 Answers
SOURCE: My Cuisinart Microwave's carousel doesn't turn.
This could be a very simple repair. The carousel is rotated by a small motor located under the bottom panel of the oven. This small motor has a coupler attached to it, that the glass tray sits on. The motor can be accessed by performing the following steps:
1. Unplug the microwave oven and open the oven door. Remove the glass tray.
2. Remove the small coupler by pulling straight up on it.
3. Close the oven door and locate the bottom panel screws UNDER the microwave oven.
4. Remove the screws and the bottom panel will open (some are hinged from the back).
5. Remove the connector plug and mountuing screws to the motor and that's it.
6. Re-install new motor using the steps provided in reverse order.
NOTE: This repair can be performed with the oven in place if it is mounted above a range. No need to uninstall. Just make sure the power is turned off to the unit before servicing anything inside.
Replacement motors can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service, with competitive pricing, so shop around for the best deal. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Aug 18, 2009
Testimonial: "The expert instructions on how to fix and replace the motor beneath my microwave's carousel was helpful and easy to follow. Thanks!"
sams_trix
  • 93 Answers
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Posted on Aug 29, 2009
SOURCE: loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Posted on Sep 08, 2009
Microwave is loud
It is normal to have a moderate sound, but if extremely loud it indicates trouble with the magnetron, should be returned for a replacement.
Apr 08, 2012 | Cuisinart CMW-100 Microwave Oven
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
My microwave comes on but does not heat. What's wrong with it?
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("runs but no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave turns on, but it does not heat the food.
http://www.microwavedisplay.com/mwd_ad_aug_2008_background.mp3
Nov 23, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave stopped heating anyting. All else appears normal.Manufactured Jan '05. Model JVM1870BF02
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit (JVM1870BF02), your symptoms (no heat), as well as the answers to these questions:
Can't heat food
So we can help you, please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar Microwave Ovens
Loud pop and microwave doesn't heat anymore
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Mar 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
deton8 von Splosion
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
