Question about Bosch Refrigerators
How do I clean out the receptacle at the back of my BOSCH refrigerator KSR38V41IE which collects the liquid from the drain hole inside
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 2651 Answers
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
  • 4 Answers
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Posted on Nov 17, 2008
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
  • 1430 Answers
SOURCE: Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at for a diagram or illustration of your refrigerator. Not all models are available.
Posted on Apr 19, 2010
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
How do i unblock the drain hole of my Miele kfn12823sd fridge freezer
Water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up like If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain lines. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 11, 2013 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
PTC22MFM - need to unclog defrost drain?
Normally, this is a job for an appliance service company. However, turn off the refrigerator and remove the rear freezer panel. Once removed you should see a drain hole. Apparently, water does not drain properly. Use an extended coat hanger, etc. to place down into the drain hole with "up and down motions". Periodically, pour a small amount of water into the drain hole until it appears to be unclogged. Then follow up with some hot water and liquid bleach (perhaps a cup full). This should kill any algae, etc. and remove any other foreign objects from the drain line. If you pour too much liquid into the drain hole you may get an overflow at the bottom of the refrigerator (there is a small drain pan underneath the appliance that catches the water during the defrost cycle. Yet, the water collected in the drain pan, during the defrost cycle, typically evaporates and you should never have to regularly empty the drain pan. Good luck!
Feb 20, 2010 | GE Refrigerators
Ice collects at base of freezer section
if drain hole is blocked ice will build up at back of unit. instead of moisture draining out it will freeze.manually defrost unit(no hot water) clean out drain hole with fine wire on small cloth dipped in clorine bleach.this will kill any nasties and inhibit regrowth.
Feb 09, 2010 | KitchenAid KSRK25FVMK Stainless Steel Side...
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Nov 03, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Ice collecting on floor of freezer and water dripping inside frig
Most likely you have a blockage in the defrost drain that begins behind the rear panel in back of the freezer and ends up in a pan beneath the refrigerator were a fan blows warm air over the water to put it back into the air inside your home. You need to unplug the refrigerator and remove the back panel inside the freezer and look at the condensate collector tray at bottom of the evaporator coil. Sometimes its ice blocking the hole because temperatures are too cold for the liquid to drain and it freezes before leaving the freezer and sometimes the line is blocked beyond the tray. Examine first and melt the ice and pour a warm solution of clorox and water in the pan and check if the amount ended up in the pan below the refrigerator. Sometimes a wet vacuum cleaner will help get what ever dislodged from the drain and sometimes we need to install something to warm the hole as the defrost takes place. But cleaning the drain is the best solution for now..Sea Breeze
Jun 22, 2009 | Whirlpool Refrigerators
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
the thumping noise is normal
Jan 13, 2009 | Refrigerators
Water collecting in Refrigerator freezer section
the drain hole could have ben clogged with dirt and now with ice as the water did not drain as it went back to freezing mode. un plug the unit, let the ice thaw for a day, open the rear cover of the freezer and clean the bottom part of the evaporator. you can find the hole at the bottom part of the drain pan. i hope i was able to help.
Jul 05, 2008 | Kenmore Refrigerators
Mar 15, 2008 | Refrigerators
Open Questions:
Bosch Fridge Freezer Model kan60a45g - Water Dispenser is not working, only a tiny dribble!! I've proven water flow to the egress / exit of the water tank... I have a Bosch American Style Fridge Freezer Model kan60a45g. The water flow out of the built in dispenser has gone from perfectly fine to a tiny dribble, it was gradual and I assumed it was the filter needing to be replaced. However replacing the filter seemed to make it worse, so I replaced filter with the plug in order to remove it from the equation. It still didn't work, so I went to the beginning of the flow and confirmed the pressure / flow into the "in pipe" was fine. I then checked flow to and from the filter unit, again fine. Down now to the inlet valve (I think it is called) and I checked all the valves worked here when required - they do. Next I checked the flow at the point of entering the water tank which sits in the fridge. It seems fine. I removed and flushed the tank and confirmed there are no problems with its flow when refitted. So sadly it seems the problem is somewhere between the exit of the water tank and the outlet in the freezer door itself. Everything else is checked out. I cannot see how the pipework runs from the fridge side into the freezer section and then up through the hinge of the freezer door. Does anyone have any suggestions? Ideally I suppose I would remove and replace the pipe - it has to be blocked somewhere I guess? Could I blast with compressed air? If anyone has experience of this issue, or knowledge of how to remove this last bit of pipe work then I would be very grateful. Thanks in advance!
Mar 01, 2018 | Bosch Refrigerators
Refrigerators Logo
29 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
