HAVE YOU FORGOTTEN TH E COAL MINERS? - Heating & Cooling
I have a tick on th etop of th emotor when th
Have you used the manufacturer's specific oil type and rating? Sometimes a switch to mineral from semi-synthetic might cause issues or using a thinner type of oil from spec.
Have you recently had an oil change?
Oct 15, 2014 | Cars & Trucks
What is silicosis?
It's a lung problem caused by breathing in mineral dust (coal, rock, concrete, gypsum,etc. The lungs can't process enough air to feed the body.
Jun 30, 2014 | Measuring Tools & Sensors
What is lime?
Hi Ken,
Lime is a calcium-containing inorganic material in whichcarbonates, oxides and hydroxides predominate. Strictly speaking, lime is calcium oxide or calcium hydroxide. It is also the name of the natural mineral (native lime) CaO which occurs as a product of coal seam fires and in altered limestonexenoliths in volcanic ejecta.[1] The word "lime" originates with its earliest use as building mortar and has the sense of "sticking or adhering
May 02, 2014 | Computers & Internet
I added coals to my Charbroil Deluxe 7000 grill, and then they disintegrated. Have I ruined the grill?
Is the grill that you are using gas? If so make sure it is compatible to use with coals. You might also be looking for briquets.
Jul 28, 2012 | Grilling
How do you condition a new grill?
Start some coals with the grate off the grill. As the coals are heating up, coat the grate in *vegetable* shortening using a paper towel. Place the grate back on the grill over the hot coals and cover. Allow the coals to burn off; this process will coat the grate with a protective layer of oil.
You might also consider running the grate through a burnoff process BEFORE curing to remove any coating the manufacturer used for protection during shipping. To do this, burn some coals for roughly 30 minutes under the grate with the lid down, let cool, then condition per previous instructions.
Jun 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
