Question about Sewing Machines
My juke mo644d serger what side needle do I use for 1 thread serging
  • Sewing Machines Master
  • 11,494 Answers
The needle "system" is determined by the manufacturer, ie 130/705. However, some sergers do use a different needle system that may be slightly longer or shorter. Getting the right one is very important for the successful use of your machine.
As far as the size of needle, that is determined usually by the fabric and the thread weight you are stitching. For example, if you are sewing chiffon with a fine thread, you would want to use a smaller size needle (like a 65), but if you are stitching denim, you would want to use probably a 90 needle with heavier thread. Be sure to consult your manual because most machines do Not recommend using a needle larger than a 90.
As for the needle type, that is also determined by the fabric you are stitching, as well as what is available in your needle system, ie a ball-point needle might work better on a knit fabric but a universal needle will probably work better on a woven cotton. For the most part, I use the same needle type for my projects unless I encounter problems, like knit fabrics running because the needle is cutting the fabric.
The following may be helpful:
All About Needles
SCHMETZ Household Needle Chart
Overlock Needles SCHMETZ Needles
Posted on Apr 17, 2017
I want to serge with 1 needle in my Juki mo644d do I use left or right side
It really depends on the look that you want. The left needle will give a bigger "seam."
Apr 17, 2017 | Juki Sewing Machines
Why won't my sl370 work?
Hello Mary.
By the question, it looks like the lower looper is making loops? If so, check that you are using the correct needles for your serger and that the needle or needles is/are inserted correctly:
- needles must be all the way up into the needle shaft
- needles must face with the flat side to the back and the groove to the front
- use at least needle size 12/80, not smaller
Check these few items, if the loops are still not forming:
- re-thread the serger from the start, keeping in mind to thread in the proper sequence (upper looper, lower looper, needles)
- make sure that the lower looper thread lays on top of the upper looper thread and is passed to the back of the serger and then under the presser foot when threading
- make sure that the thread are securely engaged IN the tension assembly
- make sure that the serger is set for 3-thread or 4-thread overlock (i.e. that the upper looper converter is not engaged)
- check all tension setting
- stitch length should be around 2.5 - 3.5
Let me know how it goes.
Happy serging!
May 02, 2015 | Sewing Machines
WHy is my Husqvarna Viking 560 serger is skipping stitches????
Here are a few things to try.
1. Make sure that correct type of needles are being used, both are the same size, and that the needle size matches the fabric weight. This is the first serger to use 15X1 needles.
2. Make sure that the needles are installed correctly and are pushed all the way up. Have you replaced the old needles with new ones, not other used ones?
3. Thread has a shelf life, it can expire over-night. Just to eliminate this possibility, replace all threads with fresh good quality serging thread (and not just another spool which was purchased some time ago).
4 It sounds like you have re-threaded the serger correctly according to manual instructions. Here is a sure fire method:
- thread the upper looper and place the thread behind the needles under the presser foot. Make sure that the thread is lying firmly between the tension discs.
- thread the lower looper (the tricky one). Check that the thread is between the tension discs as before and place the thread over the upper looper and then behind the needles, and under the presser foot.
- thread the needles, checking that the thread is between the corresponding tension discs. Place the thread under the presser foot.
5. Check stitch length.
6. Check if the problem persists with other fabric types, use two layers. If the problem occurs with only a particular fabric, then the cause is incorrect needles.
7. Check tips on both upper and lower loopers. They should be free of burs, smooth, and have a semi-sharp point.
Hopefully this will solve your problem, if not it may be time to have it inspected by a qualified technician.
Please rate how effective were these suggestion in solving your problem, it is important to me.
May 13, 2014 | Brother XL-2610
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding off the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Aug 21, 2013 | Singer 14SH654
Juno (Janome) Serger thread not interlocking?
if the serger is new I suggest taking it back and tell them what the serger is doing.
there could be a mechanical problem with the serger or it could be out of time.
Jul 25, 2013 | Janome Sewing Machines
When we thread the serger . the thread is still skipping
Are you using the corfect serger system needles in it? Most domestic sergers will take the regular domestic needle 130/705X but work best with a serger needle with has a groove down the front as well as the regular back scarf. This helps with the thread pickup from the looper by the needles. Sergers also run much faster than domestic sewing machines so the tolerances are very fine.
My Bernina came with ELX705 needles and it does run better with these in it. Also you need to use mid size needles, don't go too small, probably a size 80 or 90 is best.
Check out this page for some good info as the different serger manufacturers do have their own recommended needle sometimes.
Always refer to your manual (or ring the manufacturer if lost) to double check what needle they recommend be used in your serger, it does make a difference.
May 19, 2011 | Sewing Machines
MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Apr 05, 2009 | Janome MyLock 634D Mechanical Sewing...
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at
Aug 10, 2008 | Baby Lock Eclipse Serger
Threading a serger
Always thread the lower looper first. Then the upper looper. Finish by threading the needles.
By the way, the lower looper is the one which is always below the needle plate and the upper one is the one which travels above the needle plate.
Jul 01, 2008 | Simplicity Serge Pro SW432 Mechanical...
Left thread needle
change the knife blades
Mar 12, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
