Question about Samsung Freezers
I have never been able to depend on Ice from my Samsung refrigerator. have replaced the icemaker to no avail defrost it, it works for awhile it use to send Ice to the bottom tub. doesn't. Help
Model #RF323TEDBSR
5 Suggested Answers
  • 2039 Answers
SOURCE: freezer doesn't defrost
in the freezer there and evaporator and there and element look like a glass pipe that what make the ice melt it probably broken remove the inner panel of the freezer lock for broken glass thats our problem cheers
Posted on Jan 14, 2008
Maytag317
  • 1136 Answers
SOURCE: FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
Posted on May 24, 2009
  • 272 Answers
SOURCE: Sub zero 550 icemaker not making ice/not working
first off, make sure its under 17F in freezer as icemaker will not start above this...you need to make sure the icemaker is coming on..if so, you may just have a bad water valve. I'd put four ounces of water into the mold and see if it starts by itself dumping out your ice. if it dumps out your ice..look to see if the inlet tube that brings water into your i/m is not frozen up with ice in it..if it is, defrost with hair dryer and wait and see if it starts to work ok dumping ice.if it starts to work ok..replace fill valve..
If you find everything looking normal and your sure no ice plug in fill tube..you can try to start i/m manually..if your confident enough to work with tools and electricity...find the T and H they are close to each other on front of i/m. take an insulated wire and make a jumper that each end has 1/2 of end stripped of to go into i/m T and H..keep in there for 30 seconds and i/m should start on its own..remove jumper and either put i/m back or be ready to catch water should it come on. if no letters on front of i/m just gears. find the small 5/16 gear and turn until rake arm starts to come up. this i/m should start on its own ... if it starts and runs fills, replace i/m...if it starts , but does not fill..your inlet valve may be bad. it helps to have a volt meter for this.. you can remove top and find valve up there or its under the bottom front vent plate. locate wires that go onto valve. use your volt meter to check for 111-130 volts when you restart your i/m as already talked about. remember, it will take several minutes before you notice anything..the i/m needs to cycle first and get to the spot it fills..if you get power and no water and your sure there is water..the inlet valve is bad...
Posted on Jul 26, 2009
  • 153 Answers
SOURCE: Water source for my Kenmore freezer icemaker
yes
Posted on Feb 14, 2010
Icemaker is not working properly. It will only make ice after the reset button is pushed.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
Jun 21, 2016 | Samsung RF263BEAESR Stainless Steel 26 cu....
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Samsung model RS261MD
You have a defrost issue. This link will aid you in diagnosing and parts.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 23, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Refrigerator, freezer works but not the fridge stays at 10 c
Remove the housing that covers the evaporator inside the fresh food section and remove any ice or sludge that may be blocking the defrost drain below that evaporator. Insure no ice or water is touching the defrost sensor for that section. This is a common problem that Samsung has with it's dual evaporator refrigerators. With that drain blocked the problem will only become worse.Thanks Sea Breeze
Feb 10, 2013 | Samsung RF197ACRS 18 cu. ft. French Door...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Hello, My name Zoltan, and I have a Maytag
Your defrost element has failed in the freezer, ice has built up in the freezer cooling cores and air cant pass through them to the fridge, you need to defrost the unit totally and replace the elements, they are at the inside rear, behind the plate, also check your internal fan is running in the freezer, could be another fault. Russ
Jun 26, 2011 | Maytag Freezers
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
My whirlpool ice maker makes a noise like its growling or like a
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 15, 2009 | Whirlpool Freezers
Freezer doesn't defrost
Jan 14, 2008 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
93 people viewed this question
Top Samsung Freezers Experts
Jay Finke
Jay Finke
ray gallant
Michael Youngman
Michael Youngman
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
