Question about Exercise & Fitness
Nordick track 1000x seems to pop fuse after a few minutes of use? This just started treadmill was fine prior to this.
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: Hi, where can i get a C2100e motor control board
Two places either iconservice.com under replacment parts or Treadmill Doctor.com under treadmill products
Posted on Jul 19, 2010
SOURCE: My Nordic Track exp 1000x started stopping after
Your walk belt is worn. The friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside) When the belt wears out the cloth on the underside becomes flattened causing too much surface area to contact the walk board
Posted on Aug 23, 2010
SOURCE: Have a nordic track exp 1000x treadmill and the
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Posted on Oct 29, 2010
How to center walking belt?
Most treadmill belt adjustments are controlled by the bolts on the back of the machine on either side of track rails. Loosen opposite side of track while running and the track will move over and tighten when in desired spot. Be care not to have it running to fast or the belt will quickly move to far over. Running for a few minutes on hire speeds after adjustments are complete to make sure belt is not in need of fine tuning.
Jul 19, 2014 | Horizon Fitness T202 Treadmill - Sport...
Lights up, start does not start on console, belt won't move , decline , incline does not work, age goes down but not up, speed does not work...pulse on handles work,,,
Do you have the iFit component on your treadmill? We had a similar issue and I unplugged the iFit component (requires opening the console and unplugging the ribbon cable that attaches the iFit component) and the treadmill started working again.
Jun 08, 2014 | Nordic Track NordicTrack Treadmill, A2550
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
My nordicktrack exp1000 runs for about 20 minutes, starts to smell like its getting hot and will shut itself off, can I fix or do I have to buy a new treadmill
Step 1:
this happen because the lack of LUBE, do it
Step 2:
1) troubleshoot the main motor see my personal TIPS for motor help
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
Jan 08, 2013 | Nordic Track Nordictrack Exp 1000...
Speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Dec 10, 2011 | Exercise & Fitness
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
Hi, where can i get a C2100E motor control board for my Nordick Track C2500 ?
Jul 19, 2010 | Nordic Track NordicTrack Treadmill, A2550
Have a nordic track exp 1000x treadmill and the belt is slipping
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Exercise & Fitness Logo
26 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
