Question about Refrigerators
My Hitachi fridge isn't cooling, isnt producing ice and has an error - FO 12 - that keeps flashing. What does this mean ? The manual isnt saying anything about this. Thanks!
  • 90 Answers
SOURCE: Ice Maker Not Producing Ice
Have you reset the power? Is the bin fully inserted in the cavity? Are there any shutoff or bin full indicators that are not in the run position?
Posted on Feb 16, 2008
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
  • 1606 Answers
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Posted on Aug 16, 2009
  • 3289 Answers
SOURCE: 1996 Frigidaire Fridge/Freezer.... The fridge is
I'd check the water supply line to the fridge. If kinked of damaged, may be the source of the leak (make sure that the the connection point to the building's cold water pipe isn't leaking - and simply running down the supply line to the fridge!)
Of course, it could be a cracked solenoid valve (turns water on and off when the ice maker calls for water for ice), loose or broken clamp, broken filter (if equipped), etc. All these connection points in the water supply lines should be visible.
Unplug the fridge as soon as you can reach it before working on a wet floor with live electricity.
Please rate my reply if it was helpful - good luck!
Posted on Aug 19, 2010
Cant sign in to fixya?
Contact fixya support please. Contact info is at bottom of page.
Sep 07, 2016 | FixYa Service
My new Beko fridge freezer isnt producing ice. Dispenses water though.
It seems low refrigerant issue kindly check it by compressor conusmi amperes and current consumption of power if its different then it need to refil the refrigerant.
Jul 15, 2016 | Beko Refrigerators
What does FO 12 error code on display panel of Hitachi fridge
try going to google and put in the brand the model # and the error code
Aug 14, 2015 | Refrigerators
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
My maytag fridge isn't producing ice model #
see if the ice is frozen, there are three screws holding the ice maker in, two on top and one on bottom. The two top screws are teardrop screws and don't need to come all the way out. The bottom screw does need to come out. The electrical connection is a squeeze type and the unit should come out. Clean it out and re- insatll to see if that helps.
Jun 17, 2011 | Maytag MFD2560HES Bottom Freezer French...
Hi i have a hitachi R-M700GG8 it keeps on displaying F0 12 on my screen what does that mean?
hi my hitachi fridge is giving error fo 12 what happend with this
Jan 30, 2011 | Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Fridge tempertature
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
