Question about Bosch Hammering
Can a bad trigger cause my Bosch brute jackhammer not to run correctly
  • Bosch Master
  • 1,885 Answers
First to look for faultering contacts on electric field and carbon brushes sometimes a suppression capacitor can give some problems a worn commutator on the armature a switch can be overhauled with a direct cable contact to test to know if it is the switch test it out only with 2 persons for safety in that case.
Posted on May 06, 2017
SOURCE: 18 volt "brute tough" Bosch
You need to replace the trigger unit to correcxt the problem.
Posted on May 23, 2008
stug_57u
  • 99 Answers
SOURCE: Bosch Brute Breaker
What age is the machine? If it is fairly new it might just need to be run a while for the grease to loosen up. If it is older you will need to make sure it has enough grease. These tools don't need a great deal of grease, but too little will soon be thrown about and disperse too much. Another problem with these is if the inner cylinder, that moves up and down to create the pressure for teh striker, has a hairline crack, it can be quite hard to see when the part is dirty. When running though air will leak out and you will loose hammer action but still have plenty of vibratiion. Another thing to check is to take the piston/cylinder and striker out and hold it facing down. The striker should slide out slow and steady. If it falls out too fast then the cylinder and/or striker is worn. You may be able to rectify this by applying a bit more grease. If it doeesn't fall out at all then there is a build of grease behind the striker causing a vacum holding it all together. You can solve this by pushing the striker in a little way, and leaving it standing for an hour or so with cleaning solvent on top. It should work it's way in and help release it. It may still need to be 'persuaded' out a bit aswell.
Posted on Oct 25, 2008
brewerstool
  • 141 Answers
SOURCE: I have a Bosch brute jackhammer, I need the tool
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Posted on Sep 13, 2009
rowdy45176
  • 2176 Answers
SOURCE: have a problem with bosch brute jackhammer, quit
did you check the cord first? after that I would check the brushes and make sure the switch wired correctly. Let me know if you need more assistance.
Posted on Dec 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: need a manual for a Bosch 11304K Brute Breaker
go to Boschtool.com and on the lower left hand side you will see a box, put your model number in there and you can download one. If you still have trouble let me know and I will try another route.
Posted on Mar 27, 2010
Why my Bosch brute jackhammer only hums when I press trigger? Can someone help me please?
seems as if the jackhammer motor is locked up and frozen might wanna be careful opening it up and freeing that motor up while its unplugged
Apr 17, 2017 | Bosch Hammering
Was using my Bosch brute 70lbs jackhammer and it quit working. It only makes a humming sound when I press trigger.
Beware Time for service something does blocking the armature if that happens a bearing or other broken part.
How do i get my jack hammer to work again
measure powercable control carbon brushes that autostop in front of the carbonbrush was coming out of the brush if thats not control the electric field to brushholders and switch.
Jun 11, 2014 | Bosch BH2760VCD 1-1/8" 120V Brute Breaker...
My hitachi jackhammer runs slow and gets hot
The armature AND electric field must together replaced to get a safe working again, and the defect will not repeat if it be shure have its operating hours on it and give a full service.
May 24, 2014 | Bosch Brute Breaker Hammer 11304
My jackhammer will not run, the cord and switch are good
Check your brushes. The brushes on the Brute breaker have a spring loaded, non-conductive pin in them. When either brush wears down far enough the pin pops out and prevents damage to the expensive armature. If by chance the brushes are OK you may have to have your armature tested.
Sep 22, 2012 | Bosch Brute Breaker Hammer 11304
Have a problem with bosch brute jackhammer, quit working while using it, replaced switch, still nothing, anyone that can help?
Dec 15, 2009 | Bosch Hammering
Hammering Logo
1,901 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
