Question about Cub Cadet Garden
I have a little H flashing by the temp dial on cub cadet 1042? no idea what it means. Also every time I put it in reverse it blows its fuse?
  • 603 Answers
SOURCE: I need an owners manual for a cub cadet riding
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Posted on Mar 31, 2009
  • 85 Answers
SOURCE: Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Posted on Aug 17, 2009
SOURCE: belt keep coming off cub cadet 1042, all parts on
my cub cadet used to throw the cutter belt too....till i took the drastic step of adding a bit more tension to the belt. this was achieved by drilling another hole on either side of the chassis about 1 3/4 inches to the rearward of the machine and moving the lift arms to the new holes. Viola, more belt tension, and furthermore there is now no interference between the tensioner and the rearmost run of the belt.
Posted on Feb 18, 2010
  • 66 Answers
SOURCE: Steering problems on our 2005 Cub Cadet LT 1042
Your looking at a new steering gears at the bottom of the shaft. You can fix it if you have the time. You need to hoist the front end into the air....drop the deck, remove the nut on the steering wheel and everything pulls out the bottom of the machine.
If your not handy....send it to a good repair shop. www.nnyparts.com
Posted on May 30, 2010
roadtech7
  • 297 Answers
SOURCE: I have a 2006 Cub Cadet RZT 42 Zero Turn Mower
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
Posted on Nov 03, 2010
Testimonial: "roadtech7 was SUPER helpful and very patient. A very knowledgeable tech. Thank for all the help pardoner! "
Cub cadet lax 1042 new carb will not start just blow gas out towards the air filter will run if u spary it but will not start any other way
if it is blowing gas out you may want to check the flywheel key and valves. sounds like something is out of time or valves are not working properly.
Oct 01, 2017 | Cub Cadet Garden
How do I adjust reverse on my cub cadet 1042
there is a linkage adjustment that runs from shifter to rear end there is also a adjustment on petal if it is hydrostatic
Aug 24, 2013 | Cub Cadet Garden
The blades run all the time on my cub cadet 1042, even if the PTO is off
If your cub has an electric pto clutch it may be fused. Or the switch is stuck on. You can check the switch with multitester to see if its energized all the time. If not the clutch is probably fused. Which is cause for replacement. Adjustment only works with clutches that wont engage.
If you pto is mechanically engaged look for obstructions in the lever pathway. Also check for stuck idler pulleys.
Be careful and good luck!
Jun 04, 2012 | Cub Cadet Garden
Cub Cadet LT1042 PTO
you only need to remove the center bolt but make sure you see where the pins that keep it from spinning go this will help put it back togeather
Jun 01, 2012 | Cub Cadet Street Sign- tractor lawn riding...
May 29, 2010 | Garden
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
