Saeco exprelia E16 error code what? - Office Equipment & Supplies
2 Suggested Answers
SOURCE: error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
Posted on Dec 18, 2008
Saeco exprelia clean + lube brew group how
Put some silicone based lubricant into the long slits inside of the part that sticks out sideways. If you rotate the spindle carefully that drives the unit you will see how it slides upwards through those slits.
Oct 31, 2015 | Saeco Exprelia Automatic Espresso Machine
MY FRIGIDAIRE DRYER STOPS AND THE DISPLAY READS E16
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Apr 22, 2015 | Frigidaire Dryers
How to solve E05 problem on Saeco Exprelia?
I filled the water tank half with descaling solution (less diluted than normal - probably it was double or tripple strength) and restarted the machine several times. It kept on showing E05 each time, but it took in a small sip of the descaling, so I waited some ours and restarted it 3 times more. And repeated this for several times for 2 days. When I had almost given up, after 15-20 restarts, it primed and I could run a full descale. I forgot to weigh how much decaling it took in by each restart, that would have been nice to be able to post.
Jul 15, 2014 | Saeco Exprelia Automatic Espresso Machine...
I was descaling my exprelia coffee machine.i was asked to empty the coffee grounds unit and the drip tray. I did that and the message keeps appearing. I even turned the machine on and off. Help.
  1. Thoroughly clean the small overflow area in the drip tray. Once the drip tray gets full water flows over a small rim into this small separate part thus triggering the sensor that tells that the drip tray should be emptied. Its waals may get a bit fatty/dirty, and so remains wet and keeps triggering the sensor.
May 23, 2014 | Saeco Exprelia Automatic Espresso Machine
Saeco error codes
I don't think this is the case. The E04 code is about lubrication of the brew group. This is directly from Saeco support in Germany. However, the problem does persist. It seems to be an issue of poor design more than anything else.
Dec 22, 2013 | Saeco Coffee Makers & Espresso Machines
Our exprelia will not froth milk. It only sputters milk out when we try to make a cappacino
Arrange with Saeco to send it in for replacement under warranty, rather than repair.
Oct 20, 2017 | Saeco Exprelia Automatic Espresso Machine
We have the Saeco Exprelia and have the error message E15. We have tried turning it off and back on again but still insists on cleaning the carafe but no water is coming through - almost like its blocked...
Working for the Philips-Saeco Costumer Service, so heres your fix.
Call your Hotline, tell em about the error code.
Its about the Temperature Controller steering the boiler.
Its not sending any signals to the boiler when this happens, and the only way to fix it is to have it repaired by a certified servicer.
Ask the hotline about that.
Jan 01, 2011 | Saeco Coffee Makers & Espresso Machines
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
137 people viewed this question
k24674
jasbo
jasbo
