Question about Refrigerators
Is the internal fan supposed to run continuously in a Hitachi freezer or does it give short interval runs? (Hitachi fridge rs700ggs8)
    Master:
  • 507 Answers
Normally the fan on most can run all the time while the freezer is supposed to be cooling but in this might be an issue with any controls not working as it should otherwise it maybe normal
Posted on Apr 17, 2017
Why does my cooling fan inside the refrigerator keep running?
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Mar 05, 2015 | Refrigerators
Refrigator does not stop running
Jun 29, 2014 | Kenmore Refrigerators
Compressor working fridge is not
Not a 5 min. explanation, but in short, if the compressor and fan are both running, question is, Is the freezer cold but not the fridge? If so, defrost properly for approx. 12 hours to remove all ice then restart. If not, one of 2 options remain, there is either a Blockage in the system, or there is a leak in the system. Either way, you need to call a service technician. Truthfully, if diagnosed with a leak, i suggest you replace the fridge as these leaks do not get repaired properly especially if it is internal and good money will get wasted. Hope i helped.
Jul 29, 2013 | Whirlpool 19.6 cu. ft. Upright Freezer...
My kenmore coldspot refrigerator is warm with water forming inside yet freezer is working
It could either be a fan at the back of the freezer not working or short of gas. Some fridge/freezers control the fridge section with a fan blowing the cold air down the back when required, but all evaporator coils will ice up at the start from continuously running and trying to cool the end of the coil.
May 06, 2011 | Refrigerators
Fans in refer/freezer run continuously
it suppose to run so long the compressor is running it goes into defrost every 8 or 10 hours or it shuts off if it reaches temp but if you can hear the compressor running and the evap fan aint running somethings definitly wrong
Nov 03, 2009 | Kenmore Refrigerators
Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Jun 22, 2009 | GE Profile Bottom-Freezer Refrigerator...
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active Smart® E522BR...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Fan in the freezer stop working ater a while
You may have a serious issue with the wiring harness inside the refrigerator.  You will need to have the technician come back out and check the continuity of the wires leading from the control board to the fan checked out.  If there is no continuity, it is not repairable.
Mar 13, 2008 | LG LRSC21935 Side by Side Refrigerator
Kenmore 65092 Refrigerator
This fan will be running anytime the compressor is running. If it isn't then it has failed and will need to be replaced.
Nov 12, 2007 | Kenmore 72912 / 72914 / 72919 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
