Question about Vacuums
I checked brushes already and they all looks good.
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
WHY IS MY ORDECK XL HARD TO PUSH ON FLAT CARPETS
It could be that you need to rotate your brush or perhaps replace it. There are 5 screws that hold the base plate on, remove them and remove the base plate. Look at the bearing ends for your brush, what you are going to be looking for is a series of "hash" marks on the bearing block. If you see 4-8 "hash" marks, you need to rotate your brush and re-install it. If you only see one mark, it has already been rotated and I would recommend replacing the brush. This would also be a good time to change your belt as well. Hope this helps!
Jun 26, 2015 | Vacuums
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
HI, My Dyson DC07 Is excellent When I use the hose, But it's not so good on carpets. There is no blockage in the bottom hose & all the filters are clean. Also the belt & roller are working &...
There's a possibility the bristles on the brush are worn down so much they no longer make good contact with the carpet, hence they don't brush certain types of debris into the airflow of the powerhead.
You can check the brushes by gently stroking the palm of your hand along the brush area to see if the bristles make good contact. A visual check can also be made by looking at one side of the powerhead, line it up so you can see the other side. If the bristles can't be seen, the brush needs replaced.
Jan 15, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller brush not working. checked belts already
Make sure you follow nozzle installation procedure - check out our instructional video on our website GoodVac.com.
Good Luck,
Rocky
Dec 04, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Oreck Commercial XL 21
Check that the beater bar is completely clear of thread, this will bring the brush roll back to normal. Also check the sides of the brush roll doesn't have anything such as thread or thick string at the sides.
Jun 16, 2009 | Oreck XL21 Bagged Upright Vacuum
Bearings in the vaccum's main brush
Alot of times things get wound up on the brush roll ends and causes friction, the ends will overheat and melt, you just have to replace the brush roll(62365-2) and a new belt (61120A)while you are at it. Also check the slots where the brush sit in to make sure they didn't melt too, if so you would have to replace the base(62577).
Feb 21, 2008 | Eureka 2991AVZ Bagless Upright Cyclonic...
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
