Question about LG Cell Phones
The charging cable to my LG G5 will not stay in the port on the phone without holding it in or placing an object on it to hold it in. What could have caused this & is there a fix?
The Lg G5 is less than a year old with no apparent damage to the port, phone or charging cable. It is the original USB-C that came with the phone. Other charging cables have similar results.
  • 4 Answers
SOURCE: LG Prada
To Synchronise the Phone with the PC you must go to "connectivity" and set the USB Connection on the phone to Data Service and use the LG Sync. software. To transfer files such as photos videos or music, set to -Mass storage- and use windows explorer to Drag & drop. it's easy.
Posted on Aug 08, 2007
HeLpINHaRrY
  • 210 Answers
SOURCE: Tech support needed for my LG Prada phone
any mobile repair shop on the high street or you try vodaphone /orange or o2 shops if you are in the uk
Posted on May 19, 2009
yungdub
  • 93 Answers
SOURCE: Charging port on LG Voyager loose
time for a new phone or some super glue
i suggest you not play with the phone as much when its on the charger
Posted on Jun 14, 2009
  • 122 Answers
SOURCE: how can i use a usb cable with my lg banter phone?
from the userguide I found that you::
1. Press MENU, 9, 7
2. Use the navigation button to select a setting,
then press .ok
USB Modem/ USB Mass
Strorage/ Bluetooth/
Setting Reminder
select USB Mass storage to access files.
Good Luck
The User Guide can be found at
http://www.lge.com/us/mobile-phones/pdf/AX265%20UG%20English.pdf
search for PC connection mode
Posted on Sep 03, 2009
SOURCE: LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Posted on Jan 28, 2010
Light will not stay on after charge
are you trying to pair this device if so you need to press and hold button until light stays on hen you will need to place your phone in bluetooth setting on and in discovering mode hard to say without model number.or this device may have a faulty battery.
Aug 04, 2013 | LG HBM-760 Bluetooth Headset
Charging port on a Verizion voyager cell phone is not working properly. you can put in the charger cord but you have to hold it at a certain place and it will charge the phone but if you move it, it...
Hello. Your phone charging plug is shot and needs to be replaced. Take it to the phone store and ask them what your options are. They may just give you a new phone. Joe
Sep 17, 2010 | LG Washing Machines
Battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Jun 19, 2010 | LG VX8350 Cellular Phone
Phone won't charge or hold a charge - tried 3 different chargers and a new battery. Cleaned all connection points with alcohol. LG Vue
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
Jun 02, 2010 | LG Vu CU920 Cellular Phone
For LG enV VX9900 Phone, Silver (Verizon Wireless) My charge port is loose. When I plug in charger it moves and is not snug. It now is so loose that I have try and catch the right spot for contact and...
It is not your battery, as far it is charging when you get the right spot at the charging port.
I advice you change your charging port because it is glaring it cannot hold your charger firmly anymore that why you have to all through the stress of locating where it will charge at the charging port.
Just replace the charging port, you will see it will charge without you holding it.
To confirm that your battery is still very good, you can remove it and place in another phone, if it charge, it means it is good.
Please also try to use the charger to charge another similar phone to see if it will giving you such problem because it could also be that the charger is bad.
Take care.
Apr 14, 2010 | LG VOYAGER VX10000 Cellular Phone
My phone will not hold a charge at all. I've taken the battery out, let it set, put it back in for a few minutes and still no charge. The longest the phone lasts without dying is 10 minutes
Hello
Remove the battery and test it with a similar phone to ee if it will hold charges, if it does, it means the battery is good, but if otherwise change the battery.
Next place to look at is the charging port, check with a similar battery and charger to see if it will charge, if it doesnt, change the charging port.
Also test your charger with another similar phone to see if it will charge, if it does, it means the charger is good.
Best regards.
Feb 07, 2010 | Samsung Exclaim M550 Cell Phone
The phone port is loose and will not hold a charge
Not much you can do, it needs to either be replaced or you can have it reheated and soldered back into place on the mainboard of the phone.
Good luck! hope that helps....
Nov 28, 2009 | LG CHOCOLATE VX8500 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Charging Problem
you need to take the phone and ahve the charging port checked out to see if your port needs changing....
Mar 25, 2008 | Samsung SCH-a870 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
