Question about Kitchen Appliances - Others
How many gallons are equivalent to 24 cups - Kitchen Appliances - Others
    Top Expert:
  • 11,205 Answers
1.5 gal
Posted on Apr 17, 2017
    Habit-Forming:
  • 100 Answers
24 cups is equal to 1.5 US Gallons...
or 1.25 Imperial gallons
If you put 1\4 cup of liquid in 1 gallon, how much would you put in 2 cups?
2 cups = 1/8 gallon
1/4 cup = 2 oz.
You need 1/4 oz. liquid per 2 cups of water
= 1 1/2 teaspoons
May 12, 2017 | Kitchen Appliances - Others
2.8 oz of onion straws is how much in cups?
How much Chopped, or Sliced Onions are in a Pound?
www.howmuchisin.com/produce_converters/onion
  1. Cached
  2. Similar
How many onions do you need to purchase to measure 2 cups for a recipe? ... (2 cups), sometimes as a weight (4 ounces) and still others the onion is given ... Ancient Egyptians worshipped the onion; they believed its spherical shape and concentric rings symbolized ... ¼, ½, ¾, 1, 1 ½, 2, 2 ½, 3, 3 ½, 4, 4 ½, 5, 6, 7, 8, 9, 10.
French fried onions : Substitutes, Ingredients, Equivalents ...
www.gourmetsleuth.com/ingredients/detail/french-fried-onions
  1. Cached
  2. Similar
French's is the producer of canned "french fried onion rings" They date back to 1933 but ... 6oz can french fried onion rings = 3 cups / 2.8-oz can = 1 3/8 cups.
Onions, raw, chopped cup measurements and equivalents in grams (g ...
www.cookitsimply.com > Measurements > Onions
  1. Cached
  2. Similar
Onions, raw, chopped cup measurements and equivalents in grams (g) and ounces (oz) ... raw, chopped. equivalent values ... 1/8 cup, 20 g, 0.7 oz. 1/4 cup, 40 g ...
How much is a small/medium/large onion? - Seasoned Advice
cooking.stackexchange.com/questions/.../how-much-is-a-small-medium-large-onion
  1. Cached
  2. Similar
Mar 26, 2011 - Medium onion = 8 ounces, or about 1 cup chopped ... I've often seen large onions that were as big or bigger than "jumbo" according to this data ...
Nov 24, 2016 | Coffee Makers & Espresso Machines
2.8 oz. of dry onion straws is how much in cups?
quarter cup plus a bit
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
How much is 13 cups of water converted to gallons?
13 cups = .8125 gallons
1 cup =.0625 gallons
Jul 16, 2016 | Kitchen Appliances - Others
How much is13 cups to gallons?
1 Cup = 8 oz.
1 Gallon = 128 oz. (16 cups)
13 x 8 = 104 oz
104 divided by 128
or
13 divided by 16
Jul 16, 2016 | Wine & Spirits
147 grams of dried cranberries equals how much of a cup?
0.62133266451942 of a cup http://www.convertunits.com/from/grams/to/cups
If you meant how much of a cup if it was dried fruit substituted and equivalent to real cranberries it roughly is double the amount so 147 grams dried is equivalent to 294 grams real cranberries which is 1.2426 cups of equivalent real cranberries according to http://www.bettycrocker.com/how-to/tipslibrary/ingredients/cooking-and-baking-with-cranberries
Oct 20, 2015 | Computers & Internet
How many cups in a gallon
4 cups in a quart
4 quarts in a gallon
16 cups in a gallon
Feb 15, 2015 | Coffee Makers & Espresso Machines
925 grams equivalent in how many cups
Grams are a weight measurement, but cups are a volume measurement. There is no direct equivalent. To convert from weight to volume, you will need a conversion factor determined by the material's density.
Dec 03, 2014 | Kitchen Appliances - Others
How to replace rear wheel hub
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
  1. Raise and support the vehicle safely.
  2. Remove the wheels.
  3. Remove the brake drum or brake disc.
  4. Remove the hub grease cap.
  5. Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
  6. Remove the outer bearing and cone assembly.
  7. Remove the rear hub from rear wheel spindle.
  8. Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
  9. Remove the inner bearing cone and roller assembly.
  10. Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
  1. Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
  2. If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
  1. Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
  2. Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
  3. Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
  1. Install the hub assembly on the spindle.
  2. Install the outer bearing cone and roller assembly on the spindle.
  3. Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
  4. Install the new cotter pin.
  5. Install hub grease cap.
  6. Install brake drum or disc.
  7. Install the wheels.
  8. Lower the vehicle.
May 04, 2010 | 1998 Ford Windstar
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
