Question about Tablets & eReaders
Android Tablet voyuger 6.0 screen will not turn on what is wrong?
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
jaretheil
  • 9 Answers
SOURCE: I have an android tablet, YouTube works but when I
If you updated your operating system you may need to go and turn the auto rotate back on under options.
Posted on Nov 04, 2013
BENTECH7
  • 132 Answers
SOURCE: HAVE JUST REPLACED SCREEN ON 9 INCH A23 ALL WINNER ANDROID TABLET BEEN TOLD IT NEEDS RECALIBRATING AS NEW SCREEN NOT WORKING CORRECTLY VIA SCREEN PRESSING EXIT SCREEN NOT TURNING OFF
Calibrate through settings. Check if the flex of a touch sensors installed properly.
Posted on Mar 20, 2015
  • 44284 Answers
SOURCE: Have a locked screen on my Visual Land Prestige Android Tablet. How do I clear this
I put my finger on the lock and slide it to the right and it unlocks .
Posted on Nov 29, 2015
MY 1ST TABLET AND WANT TO KNOW WHAT I CAN DO WITH IT
Here are a few suggestions after you turn the CAPS LOCK OFF. Typing in capitals is considered SHOUTING and RUDE :>)
10 reasons you should buy an Android tablet - Buying Advice - PC ...
www.pcadvisor.co.uk > ... > 10 reasons you should buy an Android tablet
  1. Cached
  2. Similar
Nov 13, 2013 - Here's why you should rush out and buy an Android tablet. ... but you do that already, and do you trust Apple or Microsoft more anyway?)
Top 10 Worthwhile Uses for Tablets - Lifehacker
lifehacker.com/top-10-worthwhile-uses-for-tablets-1480435110
  1. Cached
  2. Similar
Dec 14, 2013 - iPad/Android: Want to eke out a little more value out of that tablet? ... And with apps Evernote, Drafts, and OneNote available, you can do more ...
6 Creative Uses for Your Android Tablet - MakeUseOf
www.makeuseof.com/tag/6-creative-uses-android-tablet/
  1. Cached
  2. Similar
7 Things to Consider If you're thinking about getting an Android tablet, these are ... You can do this with an app called Splashtop Extended Display HD, which ...
The first 6 things you need to do with your new Android tablet - CNET
https://www.cnet.com/.../the-first-6-things-you-need-to-do-with-your-new-android-ta...
  1. Cached
Dec 11, 2013 - So you now have an Android tablet. Congrats. Android tablets are arguably -- some would say inarguably -- the most versatile tablets you can ...
7 Things You Didn't Realize You Could Do With a Tablet ' Tech Life ...
techlife.samsung.com/7-things-didnt-realize-could-tablet-1469.html
  1. Cached
  2. Similar
Part of the fun of getting a new Galaxy tablet is learning its capabilities. Most of these are pretty straightforward. You know you'll be able to browse your favorite ...
18 great uses for an old Android device ' Computerworld
www.computerworld.com/.../smartphones/smartphones-18-great-uses-for-an-old-andr...
  1. Cached
  2. Similar
We all love getting new gadgets, but what to do with the old ones? Here are 18 superb ways to put your old Android phone or tablet to good use. ... You can then keep the Android device on your coffee table and use it to wirelessly cast content ...
The 100 Best Android Tablet Apps for 2016 ' Digital Trends
www.digitaltrends.com > Mobile
  1. Cached
  2. Similar
Aug 12, 2016 - Check out our picks for the best tablet apps, whether you're looking to stream music, ... 100 awesome Android apps that will transform your tired tablet ... apps and twenty different categories, but we still have a lot of work to do.
WHAT CAN DO WITH Google Search
Nov 23, 2016 | Tablets & eReaders
How do I fix my Fusion 5 tablet
How do I do a hard reset on my Fusion 5 tablet? - Android Forums ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Dec 31, 2014 - 6 posts - ‎1 author
hi, i have a fusion 5 tablet, thats all it says on the back so dont know much else on what its called, my tablet turns on but just stays on the. Chinese android tablet wifi problem
Mar 5, 2013
10.1 inch tablet ACHINGLY SLOW after ICS update ...
Oct 29, 2012
More results from forums.androidcentral.com ?
FAQ - Fusion5 - FUSION5 XTRA COMPACT Tablet PC
fusion5tablets.co.uk/index.php?route=information/information...id...
Fusion5. Frequently Asked Questions. Q. My tablet has frozen. A. This problem usually occurs when any specific app malfunctions so you need to perform a ...
A1CS Fusion 5 Stuck on Boot Up Screen ' Android Tablet Forum
www.androidtablets.net > ... > Android OS Forum > Ice Cream Sandwich
Oct 20, 2012 - 4 posts - ‎4 authors
My wifes did that and was suggested that i hold the on off button while pushing volume up (rocker button) , and that that would reset the boot up.
FUSION5 Extra - YouTube
? 1:15
https://www.youtube.com/watch?v=i4ihWLVMhCc
May 9, 2013 - Uploaded by MrOnka
FUSION5 Extra ... Theres nothing wrong with the tablet lmao you just don't know how to use one. why keep ...
Fusion5 10.1" tablet not responding ' TabletPCReview.com - Tablet ...
forum.tabletpcreview.com > ... > Windows Tablet PCs > Other Brands
Jun 24, 2012 - 2 posts - ‎2 authors
Jan 05, 2016 | Tablets & eReaders
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
Jan 21, 2015 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Why when i turn on tablet android picture appears then black screen
When you turn it on, what should appear is a little lock that you slide down to unlock the screen. If you are getting a blank screen there is probably something technical wrong with your zeepad. I would contact the company,particularly if you are still under warranty. I have had mine almost a year and have had no problems with it. When not in use, I keep it plugged in to keep it charged up. Have you charged it the full 8 hours before using?: Other than that, I am at a loss as to your problem. Wish I could be more help.
Jul 02, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
