Question about Toshiba Televison & Video
My toshiba freeview tv 40l3453DB has no picture but has audio it also is Buzzin - is it terminal or fixable ?
How to get a TV picture via the rear terminals.
Probably because the side terminals are IN{PUT} terminals (A/V signals from the source go into the TV) and the rear terminals are OUT terminals. Please read the labels next or under the terminals to make sure.
Feb 21, 2015 | Toshiba Televison & Video
Tv with no sound
Try the headphone socket if that's still working your tvs audio circuit is working , so your speakers probably need replaced.
Oct 14, 2014 | Toshiba 40BV702B 40 inch full hd lcd tv...
Iv plugged a areial into the tv and a freeview digital box but i cant get a picture????
If you see the freeview box menu then the TV is not the issue.
If you can not see the freeview box menu then the TV is either not connected to the input correctly or the TV is not on the correct input. I little common sense goes a long way , use a DVD player or other device to check the inputs yellow is video in red and white are audio. If the inputs work with a DVD player and not the freeview box then the box is defective .
Sep 18, 2010 | Televison & Video
Hello! The picture on my toshiba cz36v51 is halved vertically, and has a duplicate picture on either side. Is that fixable? This problem occurs when trying to watch movies, cable, xbox...etc. Fixable or...
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Aug 28, 2010 | Toshiba CZ36V51 36" TV
Buzzin sound not fr the lamp on a scenium hdtv
On DLP TV that sound is probably the color wheel bearings.
Apr 15, 2010 | V, Inc. VIZIO RP56 Rear Projection...
Dropped my toshiba projection tv
If is fixable but only by a tv tech . The mirror demands much precision when being installed.
I would suggest talking with Frank Zabroski SR from Audio-Tronics (a highly recommend tv shop)
The shop number is 8566670616 They do not have a website or I would list it for you. Frank can give you great support and detailed answers
Dec 30, 2009 | Televison & Video
I changed the bulb in my tv and it was working for a few days. Now I get audio but there is a wierd electrical clicking noise which made me think the new bulb broke but I still have a green light on the...
In this case there are two possibilities of what part is the one causing the issue, it coul be a ballast because of the clicking sound that caused the tv to shut off, and that buzzin sound is for your color wheel that it might not be working anymore, discountdashmerchantdotcom free troubleshoot
Jul 24, 2009 | Mitsubishi WD-65733 65" HDTV
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
