Question about Car Audio & Video
Want to install 8 inch rockford/fosgate speakers in a 6x9 existing hole, does any one make a trim ring or adapter?
bill_48632
  • 149 Answers
SOURCE: connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Posted on Aug 09, 2009
pumpkinman
  • 1165 Answers
SOURCE: It is a ringing noise that comes through the
check the ground make sure its to bear metal.
Posted on Nov 04, 2009
so_cal_steve
  • 25 Answers
SOURCE: Rockford Fosgate Spare speaker termal screws
if you have one that you can compare to another, go to home depot with that and match it up. If not, take the amp to home depot and get someone to help you find the right one.
Posted on Jan 29, 2010
shibuda
  • 1812 Answers
SOURCE: where can I get the
You should go to any electronics market,and collect proper speaker paper and spider .
Generally use quick fix for spider nearest the magnet coil and another adhesive dendrite uses for main paper.
I recommend to you please don't try to do self it is difficult.If you have the knowledge can do it.
Hope this helps
Posted on Feb 18, 2011
  • 11800 Answers
SOURCE: I have a p2 15
Only with a grille
http://www.audiovideodimension.com/rockford-fosgate-p15g-p-3652.html
Posted on Mar 21, 2011
Why did speakers get really loud, then stop working?
Have you checked the fuse on the amp and/or make sure the amp did not burn out?
Aug 01, 2015 | Rockford Fosgate Car Audio & Video
How to wire up a 15 inch 8 ohm Rockford fosgate p2?
Connect sub +speaker wire to + left channel on amp and the -speaker wire to the + right channel on amp! Then pump it up!
Dec 21, 2014 | Car Audio & Video
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
Where can I get the foam insulation rings that fit between the trim ring and the cone for my rfp3215 he2 15 inch fosgates.
Hope this helps
Feb 18, 2011 | Rockford Fosgate HE2 RFP4110 Car Subwoofer
I am looking for a 6x9 speaker template for Jensen PowerPlus693 but i cant really find one. =/
Try some web sites such as rockford fosgate.com and or kenwoodusa.com I know rockford has box building diagrams on the site. This may help, all 6x9's are the same measurements.
May 11, 2010 | Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
I HAVE A ROCKFORD FOSGATE PUNCH 12" UNGLUED AROUND EDGE THE THICK PAPER RING IS SORD OF WORN OFF SPEAKER IS IN WORKING CONDITION, WHAT WILL IT COST TO REGLUE?
This can't be glued. common problem.
You will have to find a speaker repairer who can replace the foam surround or just buy a new sub.
Jul 25, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
I have a rockford fosgate amp p3001 with 2 10" inch sub audiobahn what is the best way to set up the amp
put 2 12s pioneers on it 1200 watt each you will see your hole car shaking and the car next to you. i got it in mine and it grabbs a hole bunch of attention and itts cheap. trust me do it.
Apr 15, 2008 | Car Audio & Video
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
