Question about Coffee Makers & Espresso Machines
Coffee pot cuts offall of a sudden after an hour instead of 2 hours. How do I reset
    Top Expert:
  • Coffee Maker... Master
  • 34,170 Answers
The cutoff time may be arbitrarily set at 1 hour.
Posted on Apr 17, 2017
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
DCC-1200 coffee maker. I've had it for 2 months and the clean light came on. I have run several pots of vinegar, unplugged the machine overnight and reset to factory settings and still the machine...
Most coffee makers use a small check-valve in the feed line to the coffee basket and if a small particle gets trapped in it, the pumping action becomes erratic or very slow. To be sure any lime deposits are dissolved, use < 1 cup of Lime Away or similar product such as CLR. Make sure there is no water left in the reservoir and pour the product into it. With no coffee in the basket and the pot in place, turn on the machine and watch for the first drops into the pot, then turn off the machine again.
Let it stand for a couple of hours (I'd recommend against leaving it overnight) and then turn it back on to let it finish pumping the reservoir empty. Check the sediment in the bottom of the pot and if you see any 'crud' such as particles of lime or even a granule of coffee, you may have solved the problem.
If that seems to be the case, flush the machine with a tablespoon of baking soda and then clear water.
Good luck-
Jul 08, 2011 | Cuisinart DCC-1200 Coffee Maker
My coffee pot is very slow and only 3/4 of pot fills
With the machine full of water and still turned on, pour in 1 qt of white vinegar into the top and place decanter on base and close the lid. You will let this sit in the machine for 2 hours. At the end of 2 hours, flush out the vinegar with 8-10 decanters of water.
Jun 29, 2010 | Bunn 10 Cup Home Coffee Brewer
Our Bunn VPR coffeemaker takes a LONG time to heat up the water. If we don't wait several hours between pots of coffee, the coffee is luke-warm at best. Does this sound like a heating element or...
We left vinegar in the coffeemaker overnight. Seems to have done the trick - water is heating up now after 20 or so minutes instead of several hours.
Jan 05, 2010 | Bunn VPR Coffee Maker
Cuisinart DCC2000/how to set it to keep coffee warm for 4 hrs
From my Cuisinart DCC-2000 Series Manual: The AUTO OFF feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours.
To program the Variable AUTO OFF:
1. Turn the function knob to "Auto Off". Press and hold the "Hour" button for 2 seconds. The clock display will start blinking.
2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the "Hour" and "Minute" buttons (see "TO SET THE TIME").
TO SET THE TIME:
1. Turn the function knob to "Clock".
a. SET HOUR: Press and hold the "Hour" button to scroll through numbers quickly. When number displayed approaches the desired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct hour, the default will be the last time set unless power is shut off.
NOTE: When the number count passes 12, the PM light will be displayed on the LCD.
b. SET MINUTES: Press and hold the "Minute" button to scroll through numbers quickly. When number displayed approaches the disired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct minute, the default will be the last time set unless power is shut off. To finish setting time, turn the FUNCTION KNOB to any other setting or simply wait until the numerals stop blinking.
(P.S. The picture of the coffeemaker shown above on this page is not the correct model I have as a DCC-2000. The picture shown has a coffee pot. The DCC2000 has a coffee reservoir and a dispensing lever for dispensing coffee into mug or cup.)
Jun 13, 2009 | Cuisinart Coffeemakers
Coffee pot will not turn on ? about year old cuisinart cod-4000
I am having the same problem. All the sudden my coffee maker will not work. Called Cuisinart customer service and was told to try to unplug for 2 hours to see if it will reset. They will offer a replacement on 3 year warantee, but they are back-logged and will not say when the replacement will arrive.
Jun 07, 2009 | Cuisinart Coffee Makers & Espresso...
Funky bits in water after waiting about an hour.
If it is mold it will be removed by hot water, just cycling the machine a couple of times. If instead is scale , as I think , then it can be removed using a descaler product:Saeco: Descaling Agent Dezcal Box
May 06, 2009 | Bunn VPR Coffee Maker
Increasing stay warm time
No but I just turn it off and then on after about an hour and a half and it then resets the timer for another two hours....katherine
Apr 18, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
