Question about HP LaserJet 3030 All-In-One Printer
I have HP 3390 Laserjet MFP. The USB port no longer works
I have 3390 Laser MFP. The USB port no longer communicates with my computer. I've uninstalled and re-installed the printer software, but each time I try to print, I get a communication error. I changed USB cables to one that I know works, and still get same problem. Can I replace USB connection in printer?, what part would that be?
    President:
  • HP Master
  • 1,996 Answers
What is the exact error message you receive?You don't mention what OS you're using, but have you seen this article? Also make sure you have a good power supply to the printer. (refer here.) Possibly update your printer drivers.
Also check through these steps. Check here. And make sure you can ping the printer. ( see here).
Here's a list of resources for troubleshooting xp printer issues. There are similar available for vista here.
Finally, HP has a lot of resources available online for your printer, including parts. See here.
If you can't seem to resolve the issue with that info, write back with more details and we'll be happy to help you get it sorted out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 24, 2009
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
Hp 3390 work with w7 64x in scan mode ???
Your 3390 will only scan by using the Windows scanning software, the HP solutions do not work on Windows 7.
This is how you can scan from your 3390, assuming you have been able to get it working for printing on your system.
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
I had to reinstall the software for an HP 3390 on a Windows XP workstion. The device can print and fax. However, when I try to scan a document I get the following message: The HP imaging device could...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP LaserJet 3390 All-In-One Printer
HP Color Laser Jet 2840 keeps saying page is too complex
You can easily fix this by doing the following :
1) Go to the Main Menu on the physical printer, look for "services", under the services menu, Turn off the High speed USB
2) Check on the usb cable lenght, shouldnt be longer than 6ft
May 20, 2010 | HP LaserJet 3390 All-in-One Multifunction...
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP LaserJet 3030 All-In-One Printer Logo
201 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
