Question about Microwave Ovens
How to access fuse on a Maytag microwave mmv1153bas see 11451774jn
Include step by step procedure
  • Microwave Ovens Master
  • 9,098 Answers
May 24, 2017 MMV1153BAS - The service manual is at my site here. You can order parts here.
If you need more help, it's best to follow up with me directly. (FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on May 25, 2017
2 Suggested Answers
  • 108 Answers
SOURCE: Be more specific do you have video on how to access fuse on a Maytag microwave mod mmv1153bas serial 11451774jn step by step procedure
If ur taking the cover off a microwave "U MUST DISCHARGE BIG CAPACITOR BY SHORTING OUT WITH WELL INSULATED SCREWDRIVER OR PLIERS" fuse will be on power input board where wire enters machine
Posted on Apr 17, 2017
Apr 17, 2017 | Maytag Microwave Ovens
How do you access the fuse in a Maytag Model#MMV5000BAB
The fuse is inside. You have to remove the outer cabinet to get to it but be aware that dangerous, possibly fatal, voltages lurk inside, even with power disconnected.
Oct 23, 2016 | Maytag Microwave Ovens
My magtag over-the-range microwave (Mmv4205baq) is completely dead. It's not very old, can it be repaired?
It's probably the internal fuse.You will have to take the microwave down so you can remove the housing to get at the fuse.(I will probably install an accessable panel mounted fuse holder if this ever happens to mine-already did it on the little microwave I carry around on my work truck to heat up my lunch).
Dec 17, 2012 | Maytag MMV4205 Microwave Oven
My maytag microwave wont heat up food> model #MMV1153AAW, serial # 10394151EN
HI. Your symptoms are a strong indication Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON.
Jun 28, 2011 | Maytag MMC5000 Microwave Oven
We bought MMV1153BAS in Nov 2005 and immediately we had to have a service tech come out due to control panel would count down really fast and there was no heat. Now January 2011 the same thing is...
It sounds like the unit may be in demo mode. This is a mode entered usually after a power interruption, and the unit will act like it's on display in a store. Check in the unit's manual to see if there's a way to exit demo mode, but some of the old standards may be cutting its power off again for a few seconds, or holding down something like a stop or clear button for a few seconds.
Jan 16, 2011 | Maytag Appliances Over-the-Range Microwave...
My maytag # mmv4205aaq microwave has no power.The outlet does have power but the applianceis totaly off.Is there a internal fuse or reset switch?
It may be the line fuse, the oven thermostat, or the magnetron thermostat.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag / Whirlpool owner's manuals and installation instructions here.
Aug 18, 2010 | Maytag MMV4205 Microwave Oven
We recently had a power outage & my Maytag Microwave model #CME90108BAE is the only appliance that will not turn on. Is there a fuse with this model?
the fuse is usually mounted inside the unit on the same side as the control panel near the back end where the power cord is.......the cover must be removed to get access to it.
Jun 25, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Unit just died for no reason?
Take the cover off...comes apart many different ways on various models. Once cover is removed look for blown fuses...should be one on the main input near the power cord. May be additional fuses at the transmitter. Could also be as simple as removing input power for 15 minutes and then reconnecting; I recommend you try this step first.
Feb 07, 2010 | Maytag MMV4205 Microwave Oven
No signal came on
  1. Make sure microwave is plugged in properly.
  2. Check that door closes completely and its latch is aligned.
  3. Check that interlock switch in door works properly (required for activating microwave).
  4. Replace a blown fuse if it's accessible, or contact a service technician.
    hope this helps you
Dec 30, 2009 | Maytag MMV4205 Microwave Oven
MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Aug 04, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
91 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
