Question about Cell Phones
How to unlock modes - Cell Phones
What is the cheat code for wwe legends of wrestlmania Xbox 360
Animal's alternate costumeEnter "TheRoadWarriorAnimal" as a password to unlock Animal's alternate costume. Alternately, successfully complete Legend Tier 1 in Legend mode.
  • Brutus Beefcake's alternate costumeEnter "BrutusTheBarberShop!" as a password to unlock Brutus Beefcake's alternate costume.
  • Hawk's alternate costumeEnter "HawkFromLegionOfDoom!" as a password to unlock Hawk's alternate costume. Alternately, win three gold medals in Relive mode.
  • Jimmy Hart's alternate costumeEnter "WithManagerJimmyHart" as a password to unlock Jimmy Hart's alternate costume.
  • Koko B. Ware's alternate costumeEnter "TheBirdmanKokoBWare!" as a password to unlock Koko B. Ware's alternate costume.
  • Shawn Michaels' alternate costumeEnter "ShawnsSweetChinMusic" as a password to unlock Shawn Michaels' alternate costume.
  • The Iron Sheik's alternate costumeEnter "IronSheikCamelClutch" as a password to unlock The Iron Sheik's alternate costume.
  • The Rock's alternate costumeEnter "UnlockTheRockBottom!" as a password to unlock The Rock's alternate costume.
  • The Undertaker's alternate costumeEnter "UndertakersTombstone" as a password to unlock The Undertaker's alternate costume.
  • Hell In A Cell matchWin two gold medals in Wrestlemania Tour mode to unlock the Hell In A Cell match.
  • Ironman matchWin three gold medals in Wrestlemania Tour mode to unlock the Ironman match.
  • Steel Cage matchWin one gold medal in Wrestlemania Tour mode to unlock the Steel Cage match.
  • Quick bloodshedIn a Steel Cage match, Irish Whip your opponent into the cage to quickly make him bleed every time.
  • Read more: http://www.cheatcc.com/xbox360/wwelegendsofwrestlemaniacheatscodes.html#ixzz3SF9YEJWx
    Under Creative Commons License: Attribution Non-Commercial No Derivatives
    Sep 26, 2014 | Microsoft Xbox 360 Console
    How do I unlock motorola android 4
    If it is in network lock mode, you can unlock it using codes.. you can purchase such unlock code from any vendors online like Unlock-Zone.com
    Nov 19, 2013 | Motorola Cell Phones
    I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
    Hi!!
    I believe your alarm is in the PASSIVE MODE, here is how it works.
    PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
    CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
    Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
    • Unlock left or right front door using key.
    • Unlock all doors using remote keyless entry system.
    • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
    HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
    PROGRAMMING
    PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
    Programming Passive Mode Off
    • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
    • Lock or unlock any door with key or remote keyless entry system.
    • Open driver door.
    • Lock and unlock driver door lock knob 3 times.
    • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
    • Unlock driver door lock knob.
    • Close and open driver door 2 times.
    • Lock and unlock driver door lock knob.
    • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
    Programming Passive Mode On
    • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
    • Open driver door.
    • Close and open driver door 4 times.
    • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
    If you need further assistance, please provide an email address to send more info on your security system
    Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
    Mar 01, 2011 | Lexus RX 300 Cars & Trucks
    Had car starter installed now the passlock light stays on. He took the key out while the vehicle was running. They disconnected the battery and hooked back up but that did not work.
    Important: Using the power door unlock switch or manually unlocking the doors does not disable the Content Theft Deterrent (CTD) armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the body control module (BCM) stores the CTD mode status in memory.
    • To disarm the CTD System in arm pending mode, SECURITY indicator flashing and doors open, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle. • To disarm the CTD System in the armed mode: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle. • To disarm the CTD System when activated, alarming mode. - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle.
    Nov 04, 2009 | 2005 Chevrolet Equinox
    I searching cheats for teken 3
    you can get teken 3 cheats by downlading the PS2 cheatbook from the net
    Jul 12, 2009 | Sony PlayStation 2 (PS2) Console
    I need some cheets
    WWE SmackDown vs. RAW 2008 Unlockables Unlock Legends Go into 24/7 Mode, select the Laptop, and select WWE Shop.
    Unlockable How to Unlock Vince McMahon Defend a championship in 24/7 mode, $110,000 The Rock Defeat The Rock as Stone Cold in "Legend" Difficulty. $210,000 "Stone Cold" Steve Austin Go into the Hall of Fame and select Stone Cold. After defeating him in a Submission Match using Bret Hart, you can buy him in the WWE Shop. $210,000 **** Foley Defeat **** Foley in the Hall of Fame direct challenge mode. Afterwards, buy him in the WWE Shop. $210,000 "Ravishing" Rick Rude Buy in the WWE Shop for $210,000. "Rowdy" Roddy Piper Buy in the WWE Shop for $210,000. Terry Funk Defeat Tommy Dreamer, Sabu and Sandman in an ECW Extreme Rules 4-way match using any superstar on "Legend" Difficulty. $210,000. Sabu Buy in the WWE Shop for $210,000. Bret Hart Defeat Bret Hart in the Hall of Fame direct challenge mode. Afterwards, buy him in the WWE Shop. $210,000 Shane McMahon Buy in the WWE Shop for $110,000. JBL Buy in the WWE Shop for $110,000. Unlockable Arenas Complete Hall of Fame Task To unlock These Arenas
    Unlockable How to Unlock December to Dismember Arena Get 8 points in Hall of Fame Mode ECW One Night Stand Arena Get 7 points in Hall of Fame Mode New Year's Revolution Arena Get 9 points in Hall of Fame Mode No Way Out Arena Get 5 points in Hall of Fame Mode Summerslam arena Get 10 points in hall of fame mode. Vengeance Arena Get 6 points in Hall of Fame Mode Wrestlemania 23 Arena Get 12 points in Hall of Fame mode Great American Bash Arena Get 10 points in Hall of Fame Mode WWE SmackDown vs. RAW 2008 FAQs & Walk-Throughs FAQ/Walkthrough FAQ/Walkthrough by Dexterity_ 35K Other Attributes FAQ by Dexterity_ 21K Move List Move List by TGMasaki 255K FAQ/Move List FAQ/Move List by TGMasaki 298K Other Fighting Style FAQ by nindz 39K Other 24/7 GM Mode FAQ by pmattingly 33K
    Jul 10, 2009 | Video Game Consoles & Games
    1998 e-150 power locks are stuck in the unlock mode
    The rear door lock/unlock switch was the problem. When I took it apart, I found the wire connectors were corroded. I cleaned them up and it is now functioning well.
    Jun 20, 2009 | 1998 Ford Econoline
    How do I reprogram the 2004 Pontiac Vibe key fob?
    To begin programming, follow the procedure.
    1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
    2. Insert and remove the key from the ignition switch twice within 5 seconds.
    3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
    4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
    5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
    6. Remove the ignition key from the key cylinder.
    7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
    8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
    9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
    If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
    Jun 11, 2009 | 2003 Pontiac Vibe
    Cheats on naruto accel 2
    Unlockable Characters Beat certain events in Master (Story) Mode.
    Unlockable How to Unlock Chiyo Meet her Master (Story) Mode Chiyo with Puppets Beat Sasori True Form in Master (Story) Mode with her Deidara Beat Deidara in Master (Story) Mode Itachi Beat Itachi in Master (Story) Mode Kabuto Beat Kabuto in Master (Story) Mode Kisame Beat Kisame in Master (Story) Mode Orochimaru Beat Orochimaru in Master (Story) Mode Sai Beat Sai in Master (Story) Mode Sasori Hiruko Beat Sasori in Master (Story) Mode Sasori True Form Beat Sasori True Form in Master (Story) Mode Sasuke Beat Sasuke in Master (Story) Mode Yamato Beat Sai in Master (Story) Mode
    Jul 12, 2008 | Sony PlayStation 2 (PS2) Console
    Unlock
    Yes re-installing the firmware, it costs only about 5 bucks on small cell phone shops . it's called flashing the phone .
    Aug 28, 2007 | LG VX8100 Cellular Phone
    Cell Phones Logo
    27 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
