Question about Toro Garden
Toro 5400 d reel master center reel and rear reels won't drop. If mow switch is on, then these reels engage when I lift outside reels. Suspect damage to cpu causing this but what damaged cpu?
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
  • 319 Answers
SOURCE: threading reel to reel
Depending on which brand of recorder you have, most do have a general threading scheme. As you are facing the unit, the supply (full) reel would be on the your left and the take-up (empty) would be to the right. Position the supply reel so that the leader end of the tape will be on the outside. Pull the tape end around the shut off sensor lever so that it moves freely. Now pull the tape leader between the rubber pinch roller and capstan (in the case the unit has dual capstans). If it has a single roller on the right side, pull the tape between the heads and then between the roller/capstan. If unit has dual shut off sensor levers, pull tape around this sensor as you did the first, making sure it moves freely. Then thread the tape leader into the take-up reel slot. Press play. Both reels should turn counter clockwise.
Posted on Aug 03, 2008
  • 3 Answers
SOURCE: BLANK REELS AND A MANUAL FOR THE RCA REEL MEDIA CENTER?
You can find the manual here: http://web.archive.org/web/20050111070512/http://www.avs.ca/uploaded_files/owner_manuals/841558_reel_media_center_ib.pdf
As for the reels, there are 2 possible solutions:
1: Try to find new old stock reels. The website for Polyconcept
USA (which made the Reel media center) has been down since 2008, so the company may have gone bankrupt.
I found one internet shop that may still have blank reels for sale: www.americanbargain.com/product.asp?productid=7008
2: You can use 1/8" Nagra reels which are still being made, the tape is the same 1/8"(3.175mm) width as the tape used on the Reel Media Center.
The Nagra reels have a different hub, so you will need to improvise and make your own hub adapter.
I found reels like that on Ebay: http://cgi.ebay.com/NAGRA-SN-METAL-REELS-for-SN-SNN-SNS-SNST-10-REELS_W0QQitemZ400026885481QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item400026885481&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Posted on Jan 29, 2009
SOURCE: rear folding seat belt locked
get your dealer to replace the seat belt, depending on age, should be under warranty. Belt is defective. I have a g 2003 vue, and my dealer replaced the belt for no charge.
Posted on Feb 02, 2009
  • 175 Answers
SOURCE: Eumig 610D Super 8 projector take-up reel not
I think the Eumg 610D was a dual guage projector, capable of showing both Standard 8 and Super 8 films. (I'm basing my comments on the S810D I have in front of me, its sound "big brother").
To move between formats, there were two cogs internally that had to be changed, a film gate (two parts), and two adaptors/liners inserted into the centre of the film reels that transformed the centre from "a fat one" to "a thin one".
If the take up driver cog is rotating, but the reel is not, check whether the adaptor is in place.
You can see what they look like on eBay....
http://cgi.ebay.com/NEW-Super-8-Movie-Projector-Reel-Adapter-Film-8mm_W0QQitemZ170450331975QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27afa1a947
If the rear driver cog is not rotating, then it might be a worn/defective drive belt, in which case leave a further comment and we'll explore that.
Hope this helps
Posted on Mar 06, 2010
Testimonial: "Great, thanks--seems to work"
Looking for reel parts
OKuma is very helpful with their center pin reels.
Here's a link to their site for the center pin reels.
Okuma Fishing Products Buy Reels
open the "view models" tab then click the schematics tab for the aventa. This will open an exploded view of the reel so you can identify the parts you need. Then give them a call.
Mar 20, 2013 | Okuma Aventa Center Pin Reels, Model...
How do i replace ink cartridge
Remove the paper scroll from the printer. Turn off the power and make sure the print wheel has stopped moving.
Slide the printer cover toward the back of the machine to remove it. Lift out the old ribbon and replace it with the new one by facing the black side of the ribbon up. Secure one of the reels to its reel shaft, thread the ribbon around the outside of the metal guides, and secure the other reel to the opposite reel shaft.
Tighten any slack ribbon by turning one of the reels
Replace the print cover and reset the paper scroll.
May 02, 2011 | Sharp EL-2615G Calculator
Wheels won't engage the reel of the mower.
Pop the cover off the center of the wheel with a small flat-blade screwdriver.
Pry the lock ring off the axle, again with the flat-blade screwdriver.
Lift the wheel off.
The small gear (pinion) lifts off of its axle. You may just need to lubricate the pinion gear and the little bar of metal that it engages. If the pinion is damaged, buy new ones; they're pretty cheap.
When reassembling, the lockring is easily clicked back on with a pair of pliers.
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 17, 2009 | Great States 20" Scotts Classic Push Reel...
Reels for RCA Reel Media Center and Spirit of St. Louis are 7.5 and specaility reels that will work ONLY on these (2) machines. I bought RCA Reel Media Center several years ago and it came with only (1) tape! I stocked up when I finally located a vendor that had them for sale.
I have (50) of the reels new in the box if you would like to buy them I am willing to part with some of them.
Just Email me - UpDownTheAmFmDial@live.com
Jan 27, 2009 | Novelty Manufacturing Polyconcept USA...
Dec 07, 2008 | RCA BLANK REELS FOR THE REEL MEDIA CENTER...
The vacuum does not turn on when plugged in.
It could be either the switch, the motor, or the cord reel. Try plugging it in and slowly feeding the cord in and out while clicking the power switch on and off. If the motor kicks on while doing this, you have an intermittent short in the cord reel.
If you remove the bag chamber lid, (on the s300 series merely opening it until it makes an awful cracking sound, and then lifting it off; on the s500 series you'll have to gently pry the tab just inside the hinge away,) you will be able to access the screws to remove the rear housing. Under the exhaust filter are two screws that will allow you to remove the control unit, and then there are about five screws on the top that will need to be removed if you need to go further.
The control unit contains the switch, (in many models, but it depends on your model...) which you can test continuity through by using a VOM. If the switch checks out ok, you can test continuity through the other electrical components on the underside of the control unit. If you find a component that does not have continuity, replace it. If they all appear functional, continue with the disassembly:
On the s300 series it is easiest to flip the machine upside-down after removing the top screws, and then lifting the base away from the top housing. This will give you access to the motor and the cord reel. On the s500 series you will just have to lift the colored plastic body up and away from the base.
What can occasionally happen with these cord reels is that they can wear out, allowing too much lateral slop of the actual reel assembly. You can shim this by using something on the axle in the center to push the reel assembly back against the contacts. I use a small rubber "doughnut," but pretty much anything non-conductive will do the trick.
If this doesn't restore electrical continuity, you'll probably need a new cord reel. I highly recommend against trying to do any further repairs on the cord reel itself, as it's a nightmare to deal with... especially if the main spring comes apart. Miele does not recommend replacement of any component of the cord reel, only the entire cord reel assembly.
Any other problems will have to be referred to a repair station, since it could then be either the motor or the motor control board.
Do NOT attempt to test the motor by directly connecting it to wall voltage, as the actual power applied to the motor when it is functioning is stepped down by the circuits attached to it, and attempting to "hotwire" it will fry the motor.
Hope this helps,
-R
Aug 09, 2008 | Miele Vacuums
My miele medivac will not turn on when plugged in
If you remove the bag chamber lid, (on the s300 series merely opening it until it makes an awful cracking sound, and then lifting it off;) you will be able to access the screws to remove the rear housing. Under the exhaust filter are two screws that will allow you to remove the control unit, and then there are about five screws on the top that will need to be removed if you need to go further.
The control unit contains the switch, which you can test continuity through by using a VOM. If the switch checks out ok, you can test continuity through the other electrical components on the underside of the control unit. If you find a component that does not have continuity, replace it. If they all appear functional, continue with the disassembly:
Hope this helps,
-R
Jul 30, 2008 | Miele Vacuums
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
