Question about Hotpoint Washing Machines
My Hotpoint Aquarius washing machine WMA58P will not empty.
Runs through cycle but stops at empty stage. New pump fitted all hoses pipes filters checked. Will not empty. Cannot hear pump. Any clues please?
    Habit-Forming:
  • 100 Answers
Recheck your electrical connections. Check for power reaching the pump with a suitable tester. If there is no power then it might be the controller or that it might not be requesting the pump to operate.
Be patient...
Posted on Apr 17, 2017
Hotpoint Aquarius not completing finally spin and pumping out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Jun 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Mar 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi, my hotpoint aquarius wma42 washing machine washes ok but will not empty, i have took the filter out of the back and cleaned it, but its still doing it. can you advice
Make sure there is nothing stuck in the pump, and that the outlet hose is not blocked or kinked.
If o/k , then you need to confirm that the pump itself is working
Select drain only. or drain and spin, and you should be able to hear the pump running, if you are satisfied that there is no blockage any where and the pump is running, but no water comes out,
Then fit new pump
Plz rate my solution.
Thanks.
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Cycle stops
The filter is inside the m/c Empty this and it will work again.
you need to tip the m/c over and unto the jubilee clip on the bottom of drom to large black hose inside you can remove the white plastic filter container...this will be full of crud.
Jul 20, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
