Question about Dishwashers
May tag dish washer stopped working
Model #mdb7749aww1 was working yesterday wouldn't come on this morning
2 Suggested Answers
  • 6277 Answers
SOURCE: Hotpoint Aqualtis AQ9L29I 1200 9kg washer has
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 12, 2011
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
Frigidaire troubleshooting
Good morning friend, thank you for your post!
I understand that you are asking what the yellow light with a lock button on your Frigidaire washer means. Typically a lock symbol stands for control lock. I notice you did not provide your model number, if you comment back with your model number I would like to research to verify the information. Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. I look forward to your response.-Matt
Aug 17, 2014 | Washing Machines
Where is model number located
Good Morning Friend, thank you for your question!
I see that you are inquiring the location of the model number on your Frigidaire washer. The serial tag, which lists your model number, is typically located on the upper front, as you open the door on a front load washer. If you have a top load washer, you can find the serial tag inside the lid, on the right side. I hope this information helps to some degree. If I can be of further assistance, please feel free to reconnect.
Best regards! - Z
May 19, 2014 | Frigidaire Washing Machines
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Dishes won't come clean
Check your water inlet for the right pressure and then the water float valve for the right amount of water in the tub for washing. The tub has to have the right amount of water in it to pump it up to the top. It is also possible that the pump has debris in it that is restricting the flow. Clean out the screens and check the bottom of the washer tub for debris at the pump inlet. Use white vinegar to clean out your washer. Start your washer - open the door and pour in a lot of vinegar. Let it run for a few seconds and stop it. Let the vinegar work on the scale and debris. Start and stop it several times during the day - not completing the wash cycle until in the morning - after it has sat with the vinegar 10 -12 hours.
Mar 03, 2014 | KitchenAid 24 in. KUDP02CR Built-in...
Hotpoint Aqualtis AQ9L29I 1200 9kg washer has stopped working! It was working fine, got up one morning to load up and it wouldn't switch on! Door wouldn't open, no lights on, nothing, dead!...
John C
Aug 12, 2011 | Hotpoint Washing Machines
I have a Kenmore 80 Series Washer (Model # 20802990) and it was working fine yesterday, and today it will go through the wash, fill up and go partway through the rinse cycle and then stops. It wont drain...
the lid switch is broken this video will show you exactly how to replace it....
http://youtu.be/MFsvLiuTniU
the part#for the switch is 3949238 you can order it by going to searspartsdirect.com or look in your local phone book and find a parts dist. in your area
Jul 20, 2011 | Kenmore 24032\24036 Top Load Washer
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Dishwashers Logo
20 people viewed this question
Top Dishwashers Experts
