Question about Garmin GPS
My Garmin 2597 freezes when I plug in the supplied Garmin 12 v ac adaptor , the only way I can charge the unit is with a battery bank
    Scholar:
  • Garmin Expert
  • 186 Answers
The ac adapter may be defective. Try another ac adapter that will fit into the Garmin. If the problem does not duplicate, then replace the Garmin adapter.
Posted on May 13, 2017
I will be travelling in Europe without a car and no access to a computer. Is there a plug in adaptor for charging the battery? Can the battery be replaced, as needed?
You can purchase AC international adapters for all nuvi units, here is a link to one http://www.gpscity.ca/garmin-nuvi-zumo-international-ac-adapter.html.. For your battery it will not be able to be replaced by you the user, I only recommend replacing it through an authorized Garmin repair center.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 1370T Car GPS Receiver
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
How long does it take to charge up we just bought a new one and it was plugged in the car for 2 hrs and only lasted about 2 hrs
Garmin satnavs come with a charge out of the box. In most instances you will not need to charge before using. Your device will charge while attached to your 12V vehicle power cable.
Your device should be fully charged after applying one of the steps from above.
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
Dell latitude 810 will not power up and says low battery
if you plug in to charge your battery and its not charging replace the battery with a new one and a ac adaptor plug, just to avoid any more damage to your pc notebook, dont try to repair if you are unsure on what to do
Nov 23, 2009 | Dell Latitude D810 PC Notebook
My nuvi 260 will not display anything . It turns on okay with the Garmin introduction and then screen goes blank
Sounds like a battery problem. You may have to send to Garmin for replacement of the battery as it's not user fixable. I also highly suggest using a Garmin approved charger/ car charger if you don't have that!!
Or understand this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Oct 06, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Aug 06, 2009 | Garmin nuvi 265 Car GPS Receiver
Why doesn't my garmin nuvi 200 gps system charge?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your GPS in for battery replacement or try this:
Jun 30, 2009 | Garmin nuvi 200W GPS Receiver
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
GPS Logo
43 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
