Question about Tablets & eReaders
My tablet is stuck on a blue box with writing saying clear info stored on tpm with yes selected cant do anything
What do I do to my next book Ares 8 ? Every app I open says not responding?
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet. how do you rest nextbook tablet
Jan 07, 2018 | Tablets & eReaders
What do you do when Alcatel one touch tablet is stuck on sprint yellow screen and won't do anything
I'm not familiar with that specific tablet, but all Android devices have a way to enter a recovery mode menu that allow you to clear the cache or do a full factory reset. First, try the 'clear cache' option. If that doesn't work, you'll have to do a full factory reset (and you'll lose all of your apps and data).
  • Turn off your tablet all the way.
  • Then press and hold Volume Up + Power button until you see the Recovery Mode menu.
  • From menu on your screen choose option "clear cache" or "delete cache" by using Volume buttons to scroll and Power button to confirm.
  • Try to restart your tablet. If it still doesn't work, then do the same thing again, but this time...
  • From menu on your screen choose option "wipe data/factory reset" by using Volume buttons to scroll and Power button to confirm.
  • After that select option "Yes -- delete all user data", and confirm that.
May 04, 2016 | Tablets & eReaders
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
Jan 25, 2015 | HP Tablets & eReaders
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
How do you reset the android tablet
Hello Pamela
Your apps store was got error you can clean the cache data of your apps store to make it normal.
1. Go to Settings
2. Go to Applications
3. Select Manage applications
4. Select ALL
5. Find the App Store and click
6. then press/click the Clear Data or Clear Cache
7. Then after that restart your tablet
Try to connect on Wi-Fi then start your apps stor. If the problem not solve that's the time you most reset your tablet.
Mar 03, 2014 | Archos 101 Internet Tablet 16GB 10.1"...
Cant get any apps
Hi Kim,
Inconvenience regretted, it may happen when the Framework services are blocking the Market. Here is what you need to do:
1. Click on Menu button> Settings
2. Select Apps
3. On Top right hand side, you will see "Downloaded", scroll left to see "ALL"
4. Under "ALL" , select "Google Services Framework" and click "Clear Data".
Now try to access "Play Store" and download Apps.
Jan 28, 2014 | ASUS Google Nexus 7
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
My Tab will not turn on. It gets stuck on the verizon wireless
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Apr 02, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
