I have two conflicting folders how do v resolve tjhat
How can i formate tomtom xl 340s
The errors often occur because changes in HOME's settings conflict with the XL340S. Resetting HOME to the default settings, which requires deleting specific folders from your computer, should clear up most error messages. When returning to the default settings doesn't resolve the error, the cause of the conflict is due to the software programming or how you are using the software.
TomTom's support website has information on which folders you need to delete to reset the device, and information on resolving specific error messages when a reset doesn't work.
how about a data sync cable?
Apr 26, 2012 | Tomtom ONE XL GPS
EROR Resource Conflict -PCI in slot 03
Any conflict has to be resolved in the device manager go to control panel then system then choose hardware find your device click on it see what resource it has then attempt a change.Most likely the conflict is a glich and can be resolved by changing the resource or removing the device causing the conflict
Mar 08, 2011 | Acer Aspire 5100 Notebook
I want to reset my counter meter
I suggest this.
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will be fine right now.
If still the same, try to uninstall and reinstall the printer software to resolve the buffer conflict.
Dec 24, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
49.4cf0 service error
Try this solution :
Go to START MENU
Choose RUN
Exit
Go to C drive
Click show content
Choose spool folder
Choose printer
If still not working, try to uninstall and reinstall the printer software to resolve the conflict.
If still not working, try to check the device manager if there is error on the printer.
Dec 20, 2010 | HP LaserJet 2420dn Printer
I have a message that say Ip address conflict, what can I do
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
Nov 24, 2010 | Computers & Internet
When I install Itunes this is the Error message I get verify access npitunes.dll C:\Program Files\iTunes\Mozilla Plugins\npitunes.dll
General installation troubleshooting Important: iTunes installation is successful a majority of the time after completing these troubleshooting procedures. If one step does not resolve your issue proceed to the next.
1. Empty your Temp directory and restart
Windows XP:
  1. Choose Start > My Computer (or double-click My Computer on the Desktop).
  2. In My Computer or Computer, open the "C:" drive.
  3. Open Documents and Settings.
  4. Double-click the folder titled with your username.
  5. If you see a Local Settings folder, skip to step 10. If you don't see a Local Settings folder, proceed to the next step.
  6. Choose Tools > Folder Options.
  7. Click the View tab.
  8. Select the option to "Show hidden files and folders."
  9. Click OK.
  10. Double-click Local Settings.
  11. Right-click on the Temp folder and choose Delete.
  12. In the confirmation dialog that appears click Yes.
  13. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 11.
  14. Restart your computer.
Windows Vista and Windows 7:
  1. Choose Start > Computer
  2. In Computer, open the "C:" drive.
  3. Open the Users folder.
  5. If you see an AppData folder, skip to step 10. If you don't see an AppData folder, proceed to the next step.
  6. Choose Organize > Folder and Search Options.
  8. Select the option to "Show hidden files and folders." (In Windows 7 this option will be called "Show hidden files, folders, and drives").
  9. Click OK.
  10. Double-click the AppData folder to open it. If Windows needs your permission to continue click Continue.
  11. Double-click the Local folder to open it.
  12. Right-click on the Temp folder and choose Delete.
  13. In the confirmation dialog that appears click Yes.
  14. If you are unable to delete the Temp folder, close all programs, especially those in the Notification area ("System Tray") of the Windows Task bar and repeat step 12.
  15. Restart your computer.
2. Completely remove iTunes and QuickTime
For Windows XP, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows XP.
For Windows Vista or Windows 7, follow instructions in Remove and Reinstall iTunes, QuickTime, and other software components for Windows Vista.
Note: Songs you purchased from the iTunes Store or imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
3. Install the latest version of iTunes
Once you have completed the above steps to Empty your Temp directory, Completely remove iTunes and QuickTime, and Clean up iTunes installer files on the computer, you can install the latest version of iTunes from http://www.apple.com/itunes/download.
Additional troubleshooting Make sure you have administrator-account access To install iTunes or QuickTime software, you need to be logged in as an administrator on the computer. If you're not sure if you have administrator-account access, contact the owner of the computer or your system administrator.
Get the latest Windows updates The first thing to do when troubleshooting an installation issue on a Windows computer is make sure you have the latest Microsoft Windows updates installed—to get the latest updates, go to the Microsoft Windows Update page.
iTunes and QuickTime software for Windows require Microsoft Windows XP or Microsoft Windows Vista with latest Service Pack installed.
Disable other conflicting software In Windows, some background processes can cause issues for other programs and processes. These conflicts can prevent applications such as iTunes and QuickTime Player from installing. See Using MSCONFIG to troubleshoot conflicts in Windows XP or Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7 for assistance disabling conflicting processes.
Additionally, some third-party security software cannot be disabled using Selective Startup (MSConfig). Because of this, it may be necessary to temporarily manually disable such software while troubleshooting installation. For assistance in configuring or disabling your security software, please contact the manufacturer.
Make sure your folder names don't contain strange characters If the iTunes installer (iTunesSetup) is not responding or appears frozen after launching the installer then the folder where the installer is stored may contain unusual characters. If you notice that the iTunes installer or stored in a folder like this, either rename the folder or move the iTunes installer to another location such as the Desktop before launching.
More help If these steps don't help, you may be able to find a solution to your issue by searching the Microsoft support website.
Jul 29, 2010 | Apple iTunes
Yahoo Messenger Initializing Prob
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Failure to initialise error message ? try this download site
http://download.yimg.com/ycs/msg/dl/msgr10/us/ymsgr1000_525_us.exe
Jan 07, 2010 | Yahoo Messenger
Network adapter hardware conflicts
One good thing about having a ISP is that they want you online, so give them a call and they will be glad to help you get back online. mysleuth
Apr 28, 2009 | Computers & Internet
CDROM isn't recognized. Has interrupt conflict with hard drive
once you login to the safe mode and try to resolve it .. i am sure your problem will be resolved in the safe mode ...
because safe mode loads will the minimal set of drivers it is usually used to resolve the hardware conflicts, graphics related problems ..
you can go to the safe mode by pressing the F8 key at the system boot then you must select safe mode and press enter on it .. after that you will be in safe mode after some seconds .. then you can try to resolve the conflict ..
any further problem you can leave me a new comment ...
regards
-Dileep
Dec 03, 2008 | Compaq ProLiant ML370 G3 (340262-001)
Computers & Internet Logo
David Payne
David Payne
