Question about LG Refrigerators
I Have just bought a used LG GR232BSF Fridge/Freezer. When it was delivered I was told to leave it for 8 hours before plugging it in, apparently to allow the compressor to settle. Is this usual?
    Top Expert:
  • LG Master
  • 41,407 Answers
Yes as they laid it down moving it .
Posted on Apr 17, 2017
Testimonial: "Thanks, not being an expert, I found this useful to know."
My LG Refrigarator with a top freezer and water dispenser is frosting on the freezer and the refrigerator is warm
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 12, 2011 | LG Refrigerators
I AM HAVING LG FRIDGE. HOW WILL I CLEAR IT THE MELTING? RECENTLY PURCHASED LG 225 MODEL. HOW WILL MAINTAIN THE FRIDGE? HOW WILL SAFE?
Jul 19, 2011 | LG LRBN20520 Bottom Freezer Refrigerator
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
We've had a new fridge delivered, the Daewoo frsu20iai, how long do we need to leave the fridge standing before switching it on? Different people have told us different times ranging from 1 hour to 24...
ideally leave it for 24 hours(but it wont hurt if you switch it on staight away)the standing time is to allow any air(gas) in the system to rise to the top of the pipes.besides it gives you time to check and level the doors,so that the seals fit flat all round.dont forget to cover/wrap all food in the fridge to cut down on condensation.root veg is best kept in airtight bags.
Aug 06, 2010 | Daewoo Refrigerators
Indesit c239 freezer not getting cold red light constantly on
If you take the rear cover off the inside of the freezer you can see the evaporator coils. observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 15, 2009 | Freezers
Water in fridge
First, empty freezer and fridge. Unplug and leave door open for at least 3-4 hours. Blow out drain lines with compressed air. It is more likely that the drain line is clogged than frozen; but a clogged drain line will freeze-up quickly.
Aug 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
FF error code
The ER-FF problem that you have is: ERROR -FAN FREEZER so it means that you have a problem with maybe the fan motor or if it's a bottom mount freezer maybe ice built up on the fan motor so it's blockin the fan motor.
Hope i helped u a little bit ! :)
Francois Pelosse
Jan 19, 2009 | Freezers
Problem with GL-T 242 QM LG Fridge
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Apr 28, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
Lg side by side fridge freezer
plug it in now it should work with no problems.
Dec 14, 2007 | LG LRSC26910 Side by Side Refrigerator
Refrigerators Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
