Question about Microwave Ovens
My Bsch Fridge is only 3Y old but just stopped. Control panel is dead. Power supply ok. Any troubleshooting tips?
4 Suggested Answers
  • 6771 Answers
SOURCE: My R-4A58 unit only displays
The keypad control board will need to be replaced.
Posted on Apr 26, 2012
SD Tech
  • 14553 Answers
SOURCE: GE xl1800 I have checked both fuses and still no power to the control panel. What is the next failure?
someone needs to follow the voltage into the unit--- The voltage goes to fuse and then to inverter that drives the unit---fyi if unit is not real expensive a repair may not be practical----use some precautions if not familiar with this kind of appliance.
Posted on Jun 08, 2012
  • 40 Answers
SOURCE: we have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
Bad door switches normally don't cause fuses to fail. Typically there's 2 of them wired in series with each other so if one of those switches fail to turn off power the other one will when the door is opened.
There are a number of components that can cause a fuse to open; HV diodes, capacitors and fans, to name the most common culprits, and require the knowledge and safe use of a volt-ohm meter to efficiently find the problem.
Posted on Jun 15, 2014
Apr 26, 2012 | Sharp Microwave Ovens
Tip
How to check the High Voltage transformer in a microwave.
When your microwave is dead, you have checked the fuse and it is ok along with the power to the unit, and the control panel is dead, you probably have a bad transformer. It is the large device behind the control panel which has a laminated core. It will be hooked to the mains and supply power to various circuits.
Remove the power and the cover. Remove at least one wire from each side of the transformer. Check with a DMM for resistance. The primary, side hooked to the mains, should have continuity and low resistance, probably only several ohms. The secondary should have higer resistance but probably less than 100 ohms. If this checks out you need to see my tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat . Do not try to check the secondary under power as it will be at several thousand volts and is dangerous unless you are properly trained to do this!
If the transformer checks bad you can get a new one at a good price at http://www.repairclinic.com.
hardrocko
Thanks for using FixYa
on Mar 12, 2010 | Microwave Ovens
GE PEB2060 Control panel and everything seems to work. Makes all the right sounds but the microwave just stopped heating. It is barely a year old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 17, 2011 | Microwave Ovens
My microwave stopped working suddenly, the fuse is ok, power supply ok. It is built in can you advise please.
heatman101 ;'
May 16, 2011 | Electrolux EMS2487X Convection Microwave...
Unit is dead, no light no exhaust, no clock, no microwave power supply is fine
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 16, 2011 | Frigidaire PLMV168 Microwave Oven
Won't turn off. Light on and fan running but not heating. Power off and power on and it works for a while. Now it is just off. No lights on control panel.Power off and on and then it works for a little...
Basic
heatman101
Dec 16, 2010 | GE Profile Spacemaker II PEM31 Microwave...
Suddenly it stop working, electric supply is ok we changed fuse but still not working
heatman101
Sep 25, 2010 | Magic Chef CMV1000B Microwave Oven
GE JNM1851DM. only 6 months old and it is dead. Worked fine and then all of a sudden stopped working. The wall outlet has power so I know it is not a breaker in the house. Nothing works on the micro. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | GE Microwave Ovens
GE Adora Microwave 1850 stopped working everthing is dead. Power is ok to unit
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 21, 2010 | GE Adora DVM1850 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
